Old 05-15-2020, 02:33 PM   #1
kglowacky
brake pedal
does anyone have a picture of the( auto) brake pedal assm. they can post. I am putting together a 78 and seem to be missing a couple pieces thanks
kglowacky is offline   Reply With Quote
Old 05-16-2020, 02:43 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: brake pedal
Does this help or any of these?
https://www.lmctruck.com/interior/pe...ds-shift-boots
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 05-16-2020, 09:35 AM   #3
kglowacky
Re: brake pedal
Thnaks but all I can see is the gas pedal assm. I need a picture of the brake pedal assembly. I think I am missing some sort of pedal rubber stop so the pedal when released doesn't come up until the booster rod gets fully extended and there got to be some sort of flat plate that bolts to the hole in the petal to trip thee brake light switch. right now all I got is a bracket with the pedal hanging from it. it will swing 180 degrees if not hooked to the booster.
Old 05-16-2020, 12:40 PM   #4
Flmarine71
Flmarine71's Avatar
Re: brake pedal
Here is a pic from my 78 k5
Flmarine71 is offline   Reply With Quote
Old 05-16-2020, 12:44 PM   #5
Flmarine71
Flmarine71's Avatar
Re: brake pedal
Another one
Old 05-16-2020, 01:28 PM   #6
kglowacky
Re: brake pedal
Thanks so much. I have that bracket in a box of parts I did not know what they were. I bought this truck in pieces so thanks for the help. Is there any other brackets on the assembly that a rubber stop or something. I have a second unidentified bracket that looks somewhat like this one I need a home for.
Old 05-16-2020, 02:07 PM   #7
Flmarine71
Flmarine71's Avatar
Re: brake pedal
Those are the only two brackets on mine - nothing with any rubber stops
Old 05-16-2020, 04:40 PM   #8
Dead Parrot
Re: brake pedal
Does (or did) the truck have cruise control? If so, for some years, there was a similar bracket that held a vacuum release valve that would let air in when the pedal was pushed. The cruise system used vacuum to hold the throttle open, so no vacuum - throttle gets released.
Also possible the PO was planning on adding cruise and had picked up some of the needed parts.
Dead Parrot is offline   Reply With Quote
Old 05-16-2020, 08:22 PM   #9
kglowacky
Re: brake pedal
I think you are correct. The PO gave me a 1989 Suburban column with Cruise control. It looks a lot like the other brake light bracket with a hole in it for a switch . Great call. I apricate all the help. One more part identified.
