Old 05-15-2020, 02:47 PM   #1
Awann99
1969 only maroon gmc pictures
My truck was originally the white/maroon 1969 only color. The PO painted it a dark green. I am wanting I swap back to the original color. Would anyone have any pictures of that particular color they wouldn’t mind sharing?
Thanks fellas
Awann99 is offline   Reply With Quote
Old 05-15-2020, 04:26 PM   #2
inline67c20
Junior Member
Re: 1969 only maroon gmc pictures
Here is mine,
inline67c20 is offline   Reply With Quote
Old 05-15-2020, 06:54 PM   #3
Awann99
Thanks. I wasn’t sure where the white was originally supposed to be. I always assumed it meant a white cab tow time. Now I see that it’s only a white top.
Old 05-16-2020, 08:25 AM   #4
Boog
laying low
Boog's Avatar
There were several paint configurations available. Here is some paint info for 69-70 models.
http://67-72chevytrucks.com/vboard/s...63#post8195763
Reno Keene's '70 GMC build Charlie came with "special paint" which was black cherry, a color available on a 70 Chevelle.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-16-2020, 08:47 PM   #5
jocko
jocko's Avatar
It depends what your paint code is. Do you still have the SPID in your glovebox? If so, please post a pic of it. The pic in post two does not show the correct paint break for a conventional two tone (white roof only). The A-pillars and door window frames should also be white. It's also a possibility that you may have had a special two tone code with white/maroon which would have white below the lower molding. Would be good to know for sure before you start squirting.
Old 05-17-2020, 09:12 AM   #6
I believe your truck originally had the lower trim, at least. So it may have had white below that. That would be the most common 2-tone paint scheme for a Custom trim truck
Old 05-17-2020, 10:05 AM   #7
Awann99
Here is a Spid picture. My truck originally was about as plain as an orthopedic shoe.
Old 05-17-2020, 12:37 PM   #8
factorystock
factorystock's Avatar
1969 GMC Maroon.
factorystock is offline   Reply With Quote
Old 05-17-2020, 12:54 PM   #9
Ok, a Plain Jane. That Custom door script must be added or the door is not original. Your truck would have had the conventional 2-tone, white top.
Old 05-23-2020, 05:46 PM   #10
jnd42697
My 69.
jnd42697 is offline   Reply With Quote
Old 05-23-2020, 11:25 PM   #11
harrisoncole4
harrisoncole4's Avatar
Cool SPID! Love the '69 Maroon trucks.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858
harrisoncole4 is offline   Reply With Quote
Old 05-24-2020, 07:26 AM   #12
That SPID really is cool! I originally just looked to see it was plain and didn't have the Custom trim.
Base running gear except optional ratio, better for hiway, and leaf springs, better to haul. Wheel covers, door edge trim, and white top to trim it out. Done
Old 05-24-2020, 10:52 PM   #13
RenoKeene
Florida Edition
RenoKeene's Avatar
This is the special paint truck "Charlie" that Boog mentioned.
70 GMC Black Cherry / Ivory. Beautiful color combo.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 05-25-2020, 04:48 AM   #14
Awann99
I have always been confused about why it has leafs on the spid. I was under the assumption the all GMCs came stock with leafs wereas Chevys came with trailing arms.
Old 05-25-2020, 06:50 AM   #15
Here is a '69 K2500
