![]() Join Date: Mar 2005
Glue on or push on door rubber
Getting ready to order a rubber kit from GMC Pauls. Wondering which door rubber is better for shutting the door. I have now push on rubber and and wondering if glue on might be a little thinner and easier to close the door
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
Re: Glue on or push on door rubber
Push on,I got mine fron GMC Pauls,love them,they will be a little tight at first,but will relax,or you could loosen up your strikers,no glue is the way to go!
I have the glue on they dont fit well and the glue is a pain im going to try the push on
![]() Join Date: Sep 2017
I tried glue on but as firedemon said, total PITA... i went with a set from the junkyard from a van, cut to size... had the same tightness issue for a year but after sitting for a while they aren't too bad.
Roto Reuter thats the name...
![]() Join Date: Feb 2010
I will not use the glue on door seals any more. Some people use the new style push on door seals. Others use Dakota or Honda door seals. I tried the push on door style from Brothers, but I had to slam my doors to get them to shut properly. I bought the Honda Civic seals and my doors shut much better. There's info on this thread link.
http://67-72chevytrucks.com/vboard/s...d.php?t=801388
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
![]() Join Date: Aug 2009
2010 honda civic fit perfect, spent a whole 5.25 for the set from Pick n Pull
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
Moderator
![]() Join Date: May 2007
I’ve used all kinds; push on, glue on, Dodge Dakota seals, and the civic seals. The civic seals win out in my book. Put them on three different trucks and they all shut perfectly without slamming.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
All about them K’s
![]() Join Date: Jun 2014
I put precision push ons on my K20 last week. I’m happy with them. The mitre at the front upper corner is a nice touch. I don’t have to slam the doors but you do have to push on the handles firmly as you close the door to get them to latch if that makes sense.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
At the body shop.
The glue on was a disaster for me.
Push on are nice, but my passenger side is always off by the latch.
" That didnt make it any newer " " Dont antique the equipment " |
![]() Join Date: Aug 2018
I got my push on from steel rubber have no issue with them at all
https://www.steelerubber.com/door-se...yle-70-3881-72
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US Last edited by DA71Grande; 05-17-2020 at 07:00 AM. Reason: . |
![]() Join Date: Mar 2015
![]() Join Date: Feb 2019
I bought mine from JEGS,
Precision Door Weatherstrip Seal Kit 1967-1972 Chevy & GMC Truck 757-DWP 1112 67 1 $39.59
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#13 |
Push on, with the seam under the sill plate.
#14 |
Also don't forget to put a v notch in the ends of the rubbers to let some aie escape when you shut the door,I have seen so many that were glued at the ends with no relief for air escape,so the air trapped inside will pressurize the rubber and won!t let you shut the door without slamming it,just my 3 cents
#15 | |
#16 |
![]() Join Date: Dec 2012
I like my Sofseals, but a major pain to glue on..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
