05-16-2020, 08:55 PM | #1 |
67 C10 Driveshaft removal problem
I'm trying to put in a different transmission and I can't get the driveshaft off. I fear I might have to either pull the engine+trans or disconnect the rear end and slide it back to get it off. I don't know what to do...
It's a 67' C10, one piece driveshaft. This is the rear U joint. I can't get the U bolt out, it hit's the driveshaft. Here is the front U joint. I was thinking if I could raise the rear frame and sag the axle it might be enough. I'm working in my garage and don't have a good way to do that and I'm not sure it would even work. Do you guys have any suggestions?
67' C10 Flatbed Hot Rod |
05-16-2020, 09:06 PM | #2 |
Re: 67 C10 Driveshaft removal problem
I have never seen a yoke that far in the trans before that's going to be fun to get out . if your going with a longer trans you will need to cut the shaft anyway but might be able to loosen mounts and jack tailshaft up enough to make some space to slide it foreword a little
05-16-2020, 09:32 PM | #3 |
Post Whore
You might gain some space by disconnecting the shocks and jacking the rear of the truck up. Allowing the rear end to drop further. The increase in angle at the pinion may allow the u-bolt to come out of the u-joint.
Although looking at those u-bolts I wouldn't think twice about cutting them off. They are too rusted for me to feel comfortable reusing.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-17-2020, 11:32 AM | #4 |
Did you try to get a pry bar in between the u-joint and yoke on the rear-end and pry the driveline forword ?You can jsck the rear of truck up and put some jack stands under the frame and let the rearend hang should be able to slip it out.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
05-17-2020, 06:17 PM | #5 |
Thanks for the replies. I tried jacking up the rear frame and the driveshaft hits the center crossmember and there is still interference at the rear u joint causing it to bind up there. I pried the driveshaft as forward as I could. I think I'll try what firedemon suggested and jack up the tailshaft next.
05-17-2020, 06:29 PM | #6 |
Carefully jack up the drive shaft...
Another thing...Cab you pry around at the rear of the drive shaft, and pull those 2 u joint caps off? This would allow you to slide the drive shaft over, one side at a time to remove the "U" bolts...... THose U joints have already been replaced. GMB u joints are a lesser expensive u joint, I'd want to replace at least that joint any way...you may lose needles out of the ujoint caps doing this... |
05-18-2020, 09:37 AM | #7 |
Your driveline is obviously too long and needs to be remade to the proper length.
Your truck do as you wish, if it were me... I'd take a portable bandsaw or end/die grinder and slice it right next about 3/4" away the the weld at the rear end, then you could pull it and get it modified to the proper length. You have a situation that you need to spend the money anyway. Last edited by Sheepdip; 05-18-2020 at 11:52 AM. |
05-18-2020, 09:38 PM | #8 |
I bought a jack that goes way higher than my old one and some giant jack stands today. I jacked up the tailshaft and still couldn't get it off. I think I'm going to remove the rear end U bolts and slide it back to get it off. You are probably right Sheepdip but after I get this transmission in I'm buying new trailing arms. I will see how the driveshaft fits after installing those before I look into shortening it. I really appreciate the input fellas.
05-19-2020, 11:35 AM | #9 |
I would cut the U bolt off and figure out what to do when putting things back together.
1968 C-20 CST Vermillion http://imageevent.com/happy_dan/dantoys/68c20 2019 Silverado 2012 Camaro ZL1 |
05-19-2020, 12:04 PM | #10 |
Pull the cups off and slide the driveshaft sideways. Probably loose some needles
