Unending Project
Tach Seems high. Or am I?
when Driving down the road with 33" tires and 3.73 gears, I'm reading about 4.5k on the Tach.
:edit: I guess I am high. I meant to say that I'm doing 60mph on the speedo. If I stab it, it goes over 5k. anybody care to guess if this is right or wrong? I've got a sunpro on the shelf I could hook up, but I'm lazy and ya'll know so much. Piper! |
its all about the +6 inches
Seems a bit high.
Don't say "Oops!", Doctor
Yeah, something's wrong. With that setup you should be cruising along at about 2,500 RPM tops. Automatic tranny? Are you sure you're making the 3rd gear shift?
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
My friends car has that problem......TH350, 24" tires and a 2.70 rear end......turns about 3600 RPM to do 65 and has a top end around 110 MPH. I figure he should be doing about 2200 RPM at 65, and should be capable of doing 150 MPH with the 2.70 gears. He thinks the tach may be out, but it doesn't sound like it. Why else would be be hitting the light side of seven grand in under 3 seconds off the line, yet only running high 14's, low 15's (in a v8 vega).
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
![]() Join Date: Sep 2003
Sorry, guys, the engineer in me just had to come out. This is like one of those word problems in math class!
From what I figure, you should be turning about 2280 RPM - assuming a 1:1 3rd gear. Sometimes a 33" tire is a little smaller than 33" (My 31's are actually a hair over 30"), but even at 32" it should still be about 2350 RPM. Sounds like you're off by a factor of 2. Have you got the switch on the tach set to 8 cyl?
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
Pennyless Fool
Trans slipping??
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
![]() Join Date: Aug 2001
![]() HI PIPER .... SOUNDS LIKE YOUR TACH IS FUBAR. I RUN ABOUT 2400 RPMs AT 60 MPH IN MY BLAZER WITH 32s. HOWS WASHINGTON?? SETTLED IN OK??? DROP ME A LINE WHEN YOU GET TIME. JOHN ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
like paul72 said, ifs an aftermarket tach, make sure its set to 8cyl. mode, not 6 or 4. this will make it read higher
67 Chevy SWB - goal of a 1,000 hp weekend cruiser |
Chevy Freak
tach
In regards to the v8 vega, if he is using the stock torque converter (they were dinky), the torque converter doesn't lock up until it reaches a fairly high rpm. The torque converter could be toast too.
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
Unending Project
It's a stock tach, tho I can't tell if it's for the 8cyl or 6cyl. It's not stamped anywhere on it.
The Trans is making the shift. I know that's fine. I guess I'll hook up that other tach today and see what happens. Any reccomendations on fixing my factory tach? Thanks guys! |
There should be a hole in the back of the tach with an adjustment screw in it. Using an additional tach, you can set the stock tach by turning the screw until the two tachs match.
Piper71c10,
Love the travel trailer!!! What year and model? Here are pictures of one I had before I sold it to get my Avion Travel Trailer. http://members.cox.net/topherc/tt/1.htm Last edited by 68 Suburban; 12-11-2003 at 05:52 PM. |
#13 |
Unending Project
68 burb -- It's a 1950 Sportsman "Aloja" by Modernistic industries. 12' model.
A bigger pic : http://67-72chevytrucks.com/vboard/s...threadid=72079 Caught the edge of one side with the Uhaul on the drive up here and kindof crunched it. Looks like I'm expanding my bodyworking skills this summer. ![]() Piper |
#14 |
That is a Sweet Trailer! This is what I got rid of my Lakewood for. I still miss that little lakewood
![]() More Pics Here: http://members.cox.net/topherc/avion/1.htm Sorry to highjack your thread, but I love these old trailers ![]() |
#15 |
Unending Project
Burb- No worries. I really dig these trailers too. I think they are coming back in a major way as well. It seems like I see them on TV more and more everyday.
Dug that Black and white tile in the lakewood. Did you do that yourself? Piper |
#16 | |
You are right about these trailer. I keep getting offered more and more for my Avion. They are only going to go up in value, so if you don't need the money or the space, hold on to it. |
#17 |
I don't know if you have been to this site, but it is pretty good.
http://www.vintage-vacations.com/trailerlinks.htm |
#18 |
stock tach
My 72 cst blazer has a factory tach. I always felt like it was running a little high. When I switched to hei i bought a new tach and strapped it to the column. The old tach was running about 500-600 higher than it should at 60 mph.
#19 |
Unending Project
So, I pulled the dash to adjust the factory tach, and match it with another I've got laying around.
The factory tach is dead on at idle. Even revving it in park, it's still accurate. Only when I'm doing 60 on the highway is it off. Anyone help on this one? I S'pose you are going to tell me I need a new factory tach. ... Piper Merry Christmas everyone! |
#20 |
Unending Project
ttt, anyone?
#21 |
Without having one I cannot take it a part and see if they had an adjustment or what kind of mechanism its running in there. If it is essentially mechanical inside then there may just be a part you can change out, Im sure other year models probally used the same internals.
Does anyone have a junk one they can take apart and take a pic of the innards? Some tachs are like gauges where they run a sector and gear as their movement and sometimes a tooth goes bad on these. If I had a factory tach that works like you do I probally wouldnt take it a part and I have worked on thousands of tachs and such, without a lot of replacements I just wouldnt want to take a chance and I would live with it Steve
2008 Buick Enclave(wifes new non wrecked) 1996 Jeep Cherokee 2002 2500HD 6.0L (traded) 1998 Jeep Grand Cherokee(wifes/wrecked) 1977 DJ5 postal jeep(mmm lots of fun) 1988 Toyota 2wd p/u(DD, blewup 199,000) 1991 Toyota 2ed p/u (sry just cant break these things) 1997 XR70 Honda 1991 Z50(FOR SALE) 1972 Z50 Honda 1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end". |
#22 |
The way I look at this, is the stock tachs were never too acurate when they were new...let alone 30+ years later.
If you want a tach to look neat and to have another option...get a stock one. If you rip the truck through the gears, get a good aftermarket one. Even an Auto Zone one would be more acurate. |
#23 |
thats why i went to a 3.08 gear,on the interstate i be turning bout 4 grand!with my 3.73's
but.........i may be high too,yanno to many ''burn outs" |
#24 |
Unending Project
Ya know, It's a little circuit board on the back of the Tach. I guess i'll dump the whole cluster on ebay.
Who knows. I don't really need the tach, but it's nice to have. Thanks for the replies. Piper! |
