Heater Questions
I have an 86 chevy 4x4 and I have a problem with the Defrost and Vents working properly. When you have the Defrost on it blows out the vents and everything else but if you put it on the vents it doesn't blow out the defrost. Anyone have any idea whats the problem.
Robert Olson Transport
![]() Join Date: Oct 2002
welcome to the board
is this an air conditioned truck?
Yes, it is an A/C truck.
could be the control assembly that switches vacum to seperate ports or could be a accuator valve, or could be a stuck or bad seal on the vent door switching betwen the defrost or vent system, these things can be tricky, I have been fighting with mine which is doing the opposite of yours (mine is a 88 blazer).
here is your parts though that could be the problem. |
Take the glove box off. Behind the glove box you will see a cable that goes to the Diverter Flap. Reach over that cable till you hit the fire wall. Your hand should be directly over the Vacuum motor that controls that flap that send it dash or defroster. If that heataer core has been replaced I bet they frogot to hook the line to it. Sould be able to feel the nipple thathe line goes on. Line should loop over the box in that area.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
All right thanks for the info. I've been checking everything. I'll check that vacuum motor!!
![]() ![]() ![]() Last edited by 86chevyman; 12-12-2003 at 12:39 PM. |
