Old 05-19-2020, 09:37 AM   #1
daddyjeep
daddyjeep's Avatar
Perhaps a better way to get K30 disk brakes
Due to an issue with my right rear brake that I could never figure out. It was self adjusting and would eventually lock up. I figured the best solution would be to just ditch the drum brakes and get me some of those fancy disk brakes. I started looking into what it would take to get it done on my Dana 70 and it seems that there are not good kits available and very limited options for an e-brake. I have the Eldorado calipers on the back of my Jeep and they are giving me problems so I really don't want to go that route.
What other option is there you ask? Well, how about swapping in a complete axle with factory disk brakes? The only options here are the Ford Sterling 10.5 axle and the AAM found in Dodges and Chevys. The sterling is a great axle, I have one already that is going under the Jeep, but would require the hubs and rotors to be redrilled for the correct lug pattern. A better option is the 99-07 Chevy AAM 11.5 full float axle out of a 1 ton truck. Well, the only one I could find locally was a semi float out of a 3/4 ton and all the brakes components were gone. The guy wanted $525 for it too. A little more research and searching the on line sales places led me to a complete 03 Dodge AAM 11.5 out of a single wheel Cummins powered truck for $300. It has the same 72" WMS as my Dana 70, the correct lug pattern, the same 3.73 gear ratio, and a limited slip. Now I need to cut off the leaf spring pads and shock mounts and build some new ones to work with my truck. I am going to build the leaf spring pads with 1" of lift since I am going to lift the front a couple inches.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-19-2020, 12:51 PM   #2
Ziegelsteinfaust
Re: Perhaps a better way to get K30 disk brakes
Depending on your goals.
A shackle flip, and longer shackle could proved the lift you want. Along with a slightly softer ride, and more travel.
Either way that is a score on a great axle
Ziegelsteinfaust is offline   Reply With Quote
Old 05-19-2020, 03:39 PM   #3
daddyjeep
daddyjeep's Avatar
I am happy with my rear springs. I removed a couple from the main pack to soften it up a little, but retained the overloads so I can still handle some weight if needed. If I did a shackle flip I would have to relocate the overload pads. This truck is to tow the off road toy, not be the off road toy. I am lifting the front a couple inches just to give the suspension a little room to move.
04 1500 crew cab
Old 05-19-2020, 04:01 PM   #4
SCOTI
SCOTI's Avatar
I just crawled under a newer version of one of these this morning that one of the guys I work with just picked up.
It's an '18 model/CC/short bed but a 3/4 ton. I was surprised to see the heavier-duty trucks utilizing the 4-bar set-up & coils in the rear (I knew the 1/2 ton models went to link bar/coils). But, as I was lying there checking it out, I wondered what the width was & feasibility of swapping one of the housings under an earlier model for the factory HD disc set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2020, 07:16 AM   #5
cadillac_al
Drum brakes are cheap and easy to maintain for the average guy. Changing axles and welding perches is hard work. Call me confused, I always look for the cheap and easy way out.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-20-2020, 09:11 AM   #6
daddyjeep
daddyjeep's Avatar
I always... I mean always try to complicate the hell out of everything. Aside from that, my drum brakes have been giving me an issue since I owned the truck. The drivers' side self adjusts and locks up. I have had a half a dozen professional mechanic buddies look at it as well as thousands of us web mechanics on this group as well as Facebook. Everything is brand new on my drum brakes and many of the components have been replaced multiple times. I much prefer working on disk brakes anyway. Two bolts and the caliper comes off. No more fighting with springs and adjusters and hammering off a stubborn 70 pound drum.
04 1500 crew cab
Old 05-20-2020, 06:14 PM   #7
1976gmc20
I had that happen on my 65 C/10 stepside and I just turned the adjuster around so it wouldn't self adjust anymore
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-21-2020, 09:08 AM   #8
daddyjeep
daddyjeep's Avatar
That is completely the opposite of complicating the hell out of it. I would never consider such a thing.
04 1500 crew cab
Old 05-21-2020, 11:35 AM   #9
1976gmc20
When I worked at a service station in the mid-1970s, there were still a lot of cars around that you had to manually adjust the drum brakes.
Old 05-21-2020, 04:39 PM   #10
v30crewcab
v30crewcab's Avatar
the rear adjusters also come in a left and right configuration. could be your issue.
I put a 02 silverado 2500 rear in mine to get disc, its basically a disc version of the full float 14bolt.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
