Active Member
![]() Join Date: Aug 2003
tow hooks for sale not extreme 69-72
I have a really nice set of 69-72 tow hooks for sale
$650 shipped, buyer pays PayPal |
Active Member
Re: tow hooks for sale not extreme 69-72
Pictures
Active Member
Other side
Do they have the GM part numbers on them?
If they do, I will take them. Terry |
Active Member
They do.
I will PM you my PayPal |
Active Member
Here is the stamp
Active Member
Stamp
Still can't see the part numbers.
Even after blowing up the last two pictures you posted. Please post even closer up pictures of the part numbers. One for each hook. Thanks!!!! Terry |
Active Member
First
Active Member
Second
Active Member
Let me know if you need more pictures.
These are real factory hooks. |
Do need some more pictures.
Even closer up pics of the part numbers. The part numbers should be 394 1732-4 for driver's side and 394 1733-4 for the passenger side. Thanks!!! Terry |
#13 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I can see the 1733-4 on the one. On the other I see the 173 then probably some damage from the hook being used as a hook. Nice set of original hooks.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#14 |
![]() Join Date: Jul 2016
Those are without a doubt original factory tow hooks.
The part numbers are not very prominent on most tow hooks but can clearly be seen in the pics |
#15 |
*posting only to support the OP's claim of originality*
anyone have a set with two separate part numbers or at least a picture? both of my 69-72's look like the OP's, same p/n and foundry mark on left and right hook.. ![]() ![]() ![]()
I started out with nothing - and I still have most of it |
#16 |
They are all the same part numbers and even the extremes have the same number if they have numbers on them, extremes often don't have part numbers.
#17 |
![]() Join Date: Apr 2006
I have extremes with part numbers but they are barely there. I don’t think the reproduced ones are forged? At least that’s what I’ve heard.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
#18 |
My extremes don't have any numbers. I thought they had been worn off. The truck they came off of used them to drag logs with chains.
#19 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#20 |
I suspect the process of going extreme when making the hooks removed the very light part number that some have. Mine is barely as in you only can see the part number because you know where to look there.
#21 |
Thanks for the last pictures. Appeciated.
Absolutely believe that these are original GM tow hooks, which are all forged. But I am going to pass because I want the part numbers to be clearer on the hooks. Especially with the high cost of the original tow hooks. Thanks to the other forum members who posted input. Helped me. I did not know that part number clarity varied so much. But this is might also be caused by wearing of the forging die. So the letters are not raised as much on the tow hook. The aftermarket ones I have seen on eBay are castings. Highly recommend against using them because the forgings are significantly stronger. Realize the cast ones may be purchased for show, appearance only. But over time some subsequent owners may actually use our trucks off road and use these cast tow hooks. This would be a bad deal. GM used forgings for the greater strength. Just like other tow hooks, for example on the big Class 8 trucks. I am a retired mechanical engineer and worked many years in procurement. I purchased a lot of different designs of castings and forgings. The separate stamp/mark is not a foundry mark. Foundries only do castings. The mark is a forging companies stamp. Because the two hooks are so expensive - unobtanium, I have been studying out tow hooks for awhile now. Sorry for the long post. |
#22 |
![]() Join Date: Jun 2015
Subscribe
#23 |
Roadtrip!
![]() Join Date: Feb 2003
Most of the extremes don't have part numbers but still usually have the symbol with the "U" in it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#24 |
Scott,
I’ll take these per our PM. Thanks, Miles |
#25 |
![]() Join Date: Dec 2004
Next in line please
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
