Old 05-20-2020, 07:44 AM   #1
Minkota
Panhard / Trac Bar
Does anyone have any experience with the Panhard Bar in the link?
https://www.ebay.com/itm/Classic-Per...gAAOSwdW9Z98Q~
Minkota is offline   Reply With Quote
Old 05-20-2020, 09:35 AM   #2
SCOTI
SCOTI's Avatar
Re: Panhard / Trac Bar
This is their DBL adjustable 'short' Panhard bar that installs in the factory location. What do you need to know or questions do you have?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2020, 09:52 AM   #3
Minkota
I am curious if it is worth buying since it is half the cost of most others. and if it will work with my truck that has been lowered. I am not sure what the truck has been lowered because it was done by the previous owner. hopefully the pick will help.
Old 05-20-2020, 10:08 AM   #4
SCOTI
SCOTI's Avatar
'Short' bars aren't as effective as 'Long' bars but can still help center the rear when lowered. Long bars cost more. I used an early version of the CPP short bar on one of my trucks (only adjustable on one end). I've used Long bars since but my trucks were @ least 6-7" rear drops.
The original Panhard bar centers the rear @ stock height. Once it's lowered, the rear end is shifted over to one side slightly. The shift impacts some vehicles more than others depending on wheel tire combo & body to chassis alignment.
That bar is nice in that it allows adjusting it 'in place' like adjusting the Toe setting when doing an alignment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2020, 10:58 AM   #5
Minkota
I am not running air bags and dont plan to anytime soon so I think the short one will be ok for now at that price.
Thanks for the help.
Old 05-20-2020, 11:30 AM   #6
daddybooz
daddybooz's Avatar
I ordered same CPP from summit racing and expected ship date was late June. Cancelled and ordered from GMCPaul's and beleive it shipped yesterday. No rip on on Summit at all but a thumbs up for GMCPaul's for quick ship in today's new world.
I lowered my truck, ECE, and it came with a single hiem and it was a PIA to measure adjust etc. I've order new larger wheels and will have to be spot on to fit in wheel tubes and the double hiem will make adjustments so much easier.
My .02 cents.
Stay safe!
DaddyBooz
'68 C10 LWB
KCP 406; 400 small block, 30 over, alum heads built by Kurt Clapper
Ceramic center dumps, custom 2 1/2" SS all the way back w/MagnaFlows
2"/4" drop on 15's
daddybooz is offline   Reply With Quote
Old 05-20-2020, 11:36 AM   #7
SCOTI
SCOTI's Avatar
I'm betting you'll be 'ok' w/it. But, know the type of suspension is only part of it. It's how much drop.
The 'Short' bar goes in the factory location which for 67-72's is located @ the top/right of the differential housing over to a bracket riveted to the bottom of the Driver side frame rail. The length of the bar & it's mounting point while functional can definitely be improved.
The 'Long' bars attach to the Pass side lower truck arm which is closer to the center or just below the axle/housing centerline which is better (less side to side movement during suspension compression/extension from its length & better geometry @ that height).
No future plans for other changes in suspension set-up? Sure, run w/it.
If you might tweak things further @ a later date, I'd spend the coin once & get the better option of the Long bar. Either choice functions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2020, 03:50 PM   #8
demian5
demian5's Avatar
Ive installed these on many cars and trucks. They work fine.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-20-2020, 06:49 PM   #9
72LB
72LB's Avatar
I have one on my 69, works fine.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
