Old member
The guy doing the swap is half way there. He has the old front end out. The dang rain here is not helping though. It's been raining for over a week now and no sign of letting up. I'm so sick of this wet stuff!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2009
Re: 86 front end for the 67 Ramp
Looking good.
Going to do that swap myself. When I get to that point. Subbed for the good info you always add ![]() .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
That's gonna be cool. It's been raining in Cali too. Our rain is sporadic and light though.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Old member
The rain here is heavy and everything is full. I had to use the other lanes twice today because of flooding. Glad police where out helping with traffic.
I got the mail today and had several new parts. I ordered the adjustable propoining valve for it. I also putting a later model master cylinder in it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 05-20-2020 at 08:27 PM. |
![]() Join Date: Jan 2009
Hope those aren't Harbor Freight jack stands holding that up!! Some of those have been recalled. Might want to check that out!!
#6 | |
Old member
![]() Quote:
I'll ask but don't think they are. ![]() Randy says he hopes to have it done by end of next week if the weather will cooperate. ![]()
Old member
Went by and dropped off the brake line tubing to Randy for the brakes. He surprised me with the front end sitting under it. He had the holes lined up ready to drill. Going to order new sway bar bushing for it and have new rubber hoses alsol
Only thing we don't know yet is the steering link off the power steering gonna work are not. ![]()
You do know that MC pictured in your post #4 is a quick take-up master intended to be used with low drag calipers.
'67 GMC 2500, 292, 4spd, AC |
#9 | |
Old member
![]() Quote:
Old member
Hoping he makes some progress on the ramp truck tomorrow. It's suppose to be nice the next few days so I hope he gets on it and finish it!
Old member
Just got back from the shop. Front end is in. Went and got new rubber lines for the calipers. He said he should have it moving around by Friday. Also got new bushing for the sway bar.
I also swapped the master cylinder for a 71 C-20 one. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 06-01-2020 at 07:52 PM. |
Sounds like it's coming together....
#13 |
Old member
Yes sir. He even said it looked like the pitman arm was gonna work with the 86 center link to. That's good news. I'm hoping he has it back far enough to see it moving on it's own power by Friday!
#14 |
Awesome! I hope it works out.
