05-20-2020, 09:18 PM | #1 |
Transmission fluid seepage
Looking for some advice for my truck. I have a '68 with a TH350 and a one-piece driveshaft. One of the first things I noticed with it is that when warm and parked on an incline with the front facing up, I get seepage of trans fluid from the front yoke. In researching it would appear that there are yokes with this sort of seep hole, (pressure relief?). Is there anything I can do to prevent these embarrassing puddles? Is it possible to get a new yoke with out this opening? thanks in advance.. Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-21-2020, 07:20 AM | #2 |
laying low
Re: Transmission fluid seepage
Make sure the plastic vent tube at the top of the trans is open.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-21-2020, 08:01 AM | #3 |
The vent holes are only on the TH400's, as far as I know. The TH400's have a rubber "O" ring on the out put shaft, that seals inside the TH400 specific yoke. The TH400 yoke does not have splines inside it for the first 3-4 inches for this "O" ring to seal on.
Get under your pickup and push around on the yoke. There's a bushing the aligns the yoke. The bushing could have excessive wear allowing the yoke to be off center, allowing a slight leak, or your seal could be just leaking... |
05-21-2020, 09:22 AM | #4 | |
05-21-2020, 10:08 AM | #5 |
Thanks for the advice given - I will check these out and try to nail it down,
