Old 05-21-2020, 07:58 PM   #1
AussieinNC
Moderator
AussieinNC's Avatar
Harbor Freight Jack Stand Recall
https://images.harborfreight.com/hft...1196_61197.pdf
Urgent recall on all HF Jack Stands id numbers 56371 or 61196 or 61197
Stop using them and return to store for store credit....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 05-21-2020, 08:01 PM   #2
tdangle
tdangle's Avatar
Re: Harbor Freight Jack Stand Recall
This is why I like the old school type. Place a rod thru the holes. No chance it will get jarred and drop.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-21-2020, 08:39 PM   #3
toolboxchev
No offense to anyone in particular, but.......
As they say if the shoe fits
HARBOR FRIGHT!
toolboxchev is offline   Reply With Quote
Old 05-21-2020, 10:23 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Thanks for sharing. Can't say I'm unhappy with the Strongway, I bought four sets. That said, unbelievable anyone would produce junk jack stands, perhaps they don't know what they're for.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-22-2020, 10:46 AM   #5
Big Kev-O
Big Kev-O's Avatar
Thanks for posting! I have my rear axle out and my truck is sitting on these jack stands right now. I have been working under the truck for the past month and felt sketched out the entire time. I put the wheels and a second set of stands under there just to be safe. Just another reason to avoid HF.
The shop that is installing my locker is taking forever. Pissed off at HF, pissed off my axle is not finished. Most of all pissed off at myself for being cheap and shopping at HF. Jack stands and tarps are the only thing I have ever purchased from HF. Note to self avoid HF Chinesium.
Guess I'm going to have a lifetime supply of tarps because I certainly won't be buying another set of stands with the refund.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 05-22-2020, 02:50 PM   #6
Killer Bee
Killer Bee's Avatar
we're all of it like a cheap suit
HF jack stand recall
Old 05-22-2020, 04:52 PM   #7
MidLifer
MidLifer's Avatar
Thanks for posting. Some folks like to bash HF but if you buy correctly they are good value. I bet their jack stands come from some of the same Asian vendors as those of other more upscale stores. I choose wisely what I buy at HF. I've had good luck there with:
- Consumables - cut off wheels, nitrile gloves
- Their older line of small equipment engines, which were Honda knock-offs for 1/3 the price which I still have one on a roto-tiller, starts every time
- Air tools, hoses and fittings - same Asian vendor as Campbell Hausfield
- I have a set of combination wrenches I bought there 8 years ago that are every bit as good as my Craftsman wrenches
- Their cheap spray guns, for primer and frame painting - use them once and toss them! No need to clean them!
I stay away from their power tools and basically anything electric.
YMMV as they say but it has its place.
MidLifer is offline   Reply With Quote
Old 05-22-2020, 05:15 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
HARBOR FRIGHT!
I've also heard "Hazard Fraught".
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-22-2020, 05:45 PM   #9
OregonNed
OregonNed's Avatar
Definitely like their nitrile gloves, and a cheap oscillating tool to get all my floors done... ironically, a good oscillating blade was nearly as much as the tool!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 05-23-2020, 01:05 AM   #10
HO455
Post Whore
HO455's Avatar
Thanks for posting. Mine are 8 years old and not on the recall. I'm not a big fan of Harbor Freight but they are only 4 blocks away and stay open till 9:00 pm. Which is why I have a set of their jack stands.
RIP Bob Parks.
Old 05-26-2020, 08:14 AM   #11
daves72C10D
daves72C10D's Avatar
Thanks for the post. You in Churvull huh? I am in Vale down near Mitchems Kitchen.
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 05-26-2020, 10:05 AM   #12
71CHEVYSHORTBED402
I agree, it's hit and miss. Their wrenches, ratchet sets etc. are perfect for an ex-wife $400 I set her up H-Depot, HF & 2nd hand better than most houses by far. I'm the one who uses it most HA!
One of the best tools in my garage is a Daytona floor jack. Props HF drill bits for wood too. Sure they snap easy if you do it wrong, but they out-drill common bits that are far more expensive.
Tony
Old 05-26-2020, 06:08 PM   #13
AussieinNC
Moderator
AussieinNC's Avatar
Yep, Churvill out near Moss Lake...still have a 28021 zip...
2012 Chevy Equinox
Old 05-26-2020, 10:26 PM   #14
jocko
jocko's Avatar
I use harbor freight for simple, chunk-o-metal stuff that nobody could POSSIBLY screw up, you know, like jack stands...
I have a slew of 3 and 12 ton (a bit of overkill, but used for tractors) that look just like the recall ones, but have a different part numbers. Hmmm... Last thing I don't want not trust is my jackstands. What's next, my dog?
Old 05-27-2020, 07:01 AM   #15
That's not old school. Plenty of old school cog-type jack stands out there with no pin. That's a newer idea on the cog type. The older jack stands I've seen that use pins are the cheapest stamped steel with the pin being the only thing holding the extension up. The pin in the later cog-type is an extra safety measure. My cog-type have no pins and I never worry. When there is weight on them the handle can not lift and release. It's a great age old design that works as well today as it has all along.
Old 05-27-2020, 08:08 AM   #16
Killer Bee
Killer Bee's Avatar
problem is today's manufacturing standards aren't "age old" anymore, they're "young cheap"
especially in third world countries where respect for even their own lives is relatively low by comparison..
relying on any standard of quality these days is a gamble.. design with less chances of error is a safer bet..
lack of visibility inside a ratchet system garners less assurance than a visible pin positively engaged through a support structure..
comparing hein warner, lincoln, otc, etc., especially vintage production to modern harbor freight is imprudent with regards to quality..
ratchet type stands are not categorically unsafe, but for pete's sake at least insist on some commitment of quality..
to each their own, but when making recommendations, please remember they are often called "safety" stands for a reason
I posted this in one of the other threads, I think it's worth reading so I'll leave it here too..
I'm passionate about this as these are common tools in my trade and I supervise others that use them daily..
and while they may not be listed in these articles, Gray manufacturing makes some of the best stands IN the United States
Originally Posted by Killer Bee View Post
I'll just leave these here...
WE PICK THE BEST JACK STANDS FOR CARS, TRUCKS, AND SUV’S
Pin type adjustment for a jack stand is considered stronger than the ratcheting style and will not fail. This is why it is a favorite for heavy duty or high weight rated jack stands.
7 Best Jack Stands You Can Bet Your Life On
Ratcheting stands tend to be more convenient, but selecting a pair of stands which use pin and hole, or pin through, technology will give you the highest safety rating.
You will appreciate the pin through design because it’s safer and more dependable than a ratchet model, eliminating the fear of the stand slipping or dropping on you.
USA Made Jacks – Safe, Smart and American Made
Old 05-27-2020, 08:16 AM   #17
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Mine are so old there are no stickers or numbers on them, but they look exactly like the ones shown. I've never really trusted them and usually leave the jack or slide the ramps under the wheels for insurance. I just bought 16 ACDelco big block plugs for the 69 closed chamber heads and realized that they're made in China...Seems we cant even make toilet paper in this country anymore...Makes me sick!!! "Buy American, Be American!"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-28-2020, 12:44 AM   #18
71CHEVYSHORTBED402
Tony
Old 05-28-2020, 12:34 PM   #19
jim-bob
Hmm.. was yo dawg made in Chiner?
jim-bob is offline   Reply With Quote
Old 05-28-2020, 01:02 PM   #20
I was just saying my jack stands are safe. I've always bought quality shop equipment from professional-grade shop equipment dealers.
Old 05-28-2020, 01:49 PM   #21
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Same, 90% of my shop tools / equipment is USA made that I've had to research to find new or found used on eBay.
My two sons are starting to recognize the quality of tools that they have compared to mine. I think they are starting to mark'em as to who gets what when I crook.
American, Japan and German steel is the best. India and Romania is OK, coming in last is Taiwan and dead last is Chinese.
Harbor Freight and Northern Tool is so darn coinvent to get anything. To bad Sears and craftsman went upside down.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-30-2020, 09:32 AM   #22
71CHEVYSHORTBED402
I know those old pin style stands, I may have used them once. Waste of $8.99 I'm guessing, K-mart or Grand Auto for certain. Cheap is always better when you're a kid and don't know better. I wised up to cheap along time ago. Today I just buy stuff in error well too often, like the 4 pair of Vic Firth 7A I rec'd last week when the goal was 5A
Tony
Old 06-12-2020, 06:22 PM   #23
Killer Bee
Killer Bee's Avatar
Old 06-13-2020, 07:04 AM   #24
53burb
53burb's Avatar
http://www.msn.com/en-us/autos/news/...6S8?li=BBnb4R5
53burb is offline   Reply With Quote
Old 06-13-2020, 07:11 AM   #25
The labels on my old Blackawks are aluminum, much stronger than a sticker
That is just ridiculous. Great to know since HF put out flawed and dangerous jack stands they had to recall, the next ones they put extra effort into assuring the quality. At least this problem is less likely to cause a sudden drop. And if you got under a vehicle with a jack stand without seeing that, shame on you
I think I have it all figured out now. Manufacturing went over to China but quality control stayed in America. Welcome to the largest quality control team on the planet!
