05-22-2020, 05:47 PM | #1 |
1978 "Big 10" rear end question
There is a '78 c/10 big 10 a few hundred miles south of my location that has a 5 lug rear axle. I would imagine it is a 12 bolt rear end if it is stock, no?. Aside from this special truck having beefed up suspension, does anyone know if GM gave these trucks limited slip rear ends or was that an option you had to have the dealer order for you back in the day? Any help would be appreciated.
05-22-2020, 07:56 PM | #2 | |
Re: 1978 "Big 10" rear end question
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-22-2020, 08:42 PM | #3 |
Fantastic, thanks for the information. Yes, I am starting to recall that G80 code.
Tell me one more thing if you're aware. Did GM use this code for several years on trucks and vans. I know vans came with some limited slip rear ends and some times I find them in the junk yards and read the build sheets under the hood to see if it has a limited slip carrier. I know the axles are too wide for a pickup but that would be half the battle in building one. Thank you. |
05-22-2020, 09:21 PM | #4 |
78 Big10 454
No complaints with the limited slip in my 78. Glad to have it with a 454.
1978 Chevy SWB C-10 2WD 454/400 |
