05-23-2020, 01:06 AM | #1 |
Nos door handles, inside button longer
Nos door handles, have a long button on them and ones that came off have a shorter button on them. Why is there a difference, can I just cut them to the same length as the old ones. Button that pushes on the door latch. Thanks
05-23-2020, 02:34 AM | #2 |
Re: Nos door handles, inside button longer
68-72 door handles are the same 67 are different. How they are different I do not know. Maybe your nos handles are for a 67 or the truck doors/handles are from a 67. Hopefully someone who knows the difference will chime in.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-23-2020, 11:39 AM | #3 | |
The Older Generation
Maybe they are for the Suburbans and Panel trucks with the rear barn doors. The shaft on those are longer and they are hard to find NOS.... I wouldn't cut them off until you find out for sure. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-23-2020 at 12:07 PM. |
05-23-2020, 12:47 PM | #4 |
Roadtrip!
I think this is correct...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-23-2020, 03:19 PM | #5 |
I bought a pair of NOS a while back one was long the seller(another board member) told me the same thing for suburban rear door and just trim it off
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-23-2020, 10:53 PM | #6 |
Thanks all. They are still in the GM boxes. I think they are suburban handles too. From the info I have found. Just wanted the boards opinion. Thanks again
05-24-2020, 08:48 PM | #7 |
You got me curious. I just picked up a set of repop door handles and decided to do a comparison. From the pictures, you can see that the pin is much longer.. around an 1/8 inch or more. Also, the spring on the repop is much smaller than original, and the button seems to not operate as smoothly. I think that I am going to return the new ones, and just try to polish up my old pitted chrome ones. Definitely some cheap Chinese made junk.
05-24-2020, 11:32 PM | #8 |
If I could just learn how to post pics, I would! need a little help! thanks
05-25-2020, 07:02 AM | #9 |
Pictures from your computer folders?
1- hit "Go Advanced" 2- Scroll down and hit "Manage Attachments" 3- A window pops up with 5 "browse" buttons, hit one 4- You will be looking at your picture folders, find the picture you want to post 5- Double click one picture you want 6- Click "Upload" and that picture will be posted
05-25-2020, 10:46 PM | #10 |
Thanks, I will give it a try. Thanks again
05-26-2020, 11:40 AM | #11 |
One of the First
In the past, I've trimmed the longer stud down. No issues with fitment on a truck door. The difference in 67 and 68-72 door handles is the alignment of the screw holes in the handle. 67 doors have a plate on the inside where you mount the outer handle to the door. 68-72 doors you bolt straight to door skin, no inner plate.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
05-26-2020, 08:24 PM | #12 |
Trimmed them today and they worked perfectly. Thanks for all your help! Still have to work on uploading pictures. Thanks
