Old 05-23-2020, 12:11 PM   #1
Larry Weaver
Quadrajet TV cable
I have just installed a 700R4 in my stock 68 C20 with a quadrajet.I need to be able to connect cable to carb correctly. I have bracket to hold cable at correct angle the goes on back of carb but I need the part with stud on carb. I have not found any after market "corrector" or adapters that spell out for Quadrajet. What have you guys had luck with? I have been looking for a qjet from that era to get the part I need but not having any luck. Thanks
Larry Weaver is offline   Reply With Quote
Old 05-23-2020, 12:22 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Quadrajet TV cable
Have you tried Bowtie Overdrives?
http://bowtieoverdrives.com/catalog/...AT&CATID=WA3A4
RIP Bob Parks.
Old 05-23-2020, 12:24 PM   #3
geezer#99
geezer#99's Avatar
Some studs here.
Not sure which you need, but a source for them.
https://quadrajetparts.com/quadrajet...-c-128_52.html
And maybe some here. They’ll likely know what you need.
https://www.bowtieoverdrives.com/
Old 05-23-2020, 12:43 PM   #4
Larry Weaver
The correct carb (1982) has a arm on the main throttle shaft,driver side, that has correct geometry and the stud that cable hooks to. The older Qjet does not have it ,there are many items listed out there but have yet to find one the says for Qjet. My original thought was find a 82 Qjet and use the throttle shaft from that carb on the older one.
Old 05-23-2020, 12:52 PM   #5
Smitty
Smitty's Avatar
As previously stated. Bowtie Overdrive has something for every application.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-23-2020, 07:08 PM   #6
jayoldschool
Moderator
I would think that Edelbrock has an adapter. Have a look at their stuff.
jayoldschool is offline   Reply With Quote
