Old 05-23-2020, 09:42 PM   #1
67see10
67see10's Avatar
327/3onTree for a 350/700r4 swap
I am in the process of swapping out the 327/three-on-tree for a 350/700r4 swap in my 67 Suburban. I had a few questions in regards to the swap. There are two salvage yards in my area that has tons of 67-72 c10 and a few suburbans. I was planning on going out there to pick parts.
1) Can I use a automatic transmission cross-member out of a truck or suburban for the swap?
2) Am I okay to use any automatic column shift steering column from a 67-72 Truck, Suburban, etc?
Instagram: @petestruckfarm
67see10 is offline   Reply With Quote
Old 05-24-2020, 12:17 AM   #2
HO455
Post Whore
HO455's Avatar
Re: 327/3onTree for a 350/700r4 swap
Yes to both.
RIP Bob Parks.
Old 05-24-2020, 01:44 AM   #3
67see10
67see10's Avatar
Yes to both.
Thanks. Are they any other parts I need to pull? I have the correct brake pedal Assembly installed. And figured that I have to do a electronic speedo to mechanical speedo conversion on my trans. I also plan on using a lokar shift linkage
Old 05-24-2020, 09:15 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
There is a little difference between the '67-'68 and '69-'72 columns. The '67-'68 shaft is one piece all the way down to the steering box and the '69-'72 is two piece with an intermediate shaft from the bottom of the column to the box. There are also two different size splines on the steering boxes and rag joints.
LockDoc
Leon
