![]() Join Date: Jul 2013
Easiest/cheapest way to lower?
I have a 67 C10 longbed and after replacing the old farm bumper with a chrome one I can really tell how much higher the back end is. I've never lowered a vehicle before and just wondering what's the easiest/cheapest way to drop the back end 3 or 4 inches
Re: Easiest/cheapest way to lower?
New, dropped springs would be quickest/easiest legit way.
Post Whore
![]() ![]() Join Date: May 2015
Way back when I was younger we would cut coils and remove leaf's to drop one...cost-free
But you may need to do some work on the shocks.. Nowadays like Scoti says springs would be the ideal way
#4 | |
We started cutting them. We used different methods to keep them located in the rear. Better ride quality vs the torched method of heating to collapse the length but still not like drop springs now readily available.
Drop blocks 1 1/2 then springs.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
This is what I would do. I would try to keep as long as spring as possible so long as you don't run into scrub line issues.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
While I agree w/you both that it's the better way, it's not the easiest/cheapest because you're paying for a drop spring plus a drop block & new U-bolts vs. just paying for a drop spring.
A good set of progressive 3” or 4” drop springs and spring retainers will cost about $200 or less. Get from summit and get free shipping.
If you aren’t kidding the front I would not go any more than 3” total in the rear.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
Huh? Would you elaborate on this statement?
Sorry about that. Working on my phone and autocorrect got me. If you aren’t lowering the front I’d not lower the rear more than 3” total.
67-72 parts collector,…
![]() Join Date: Nov 2002
Easy and cheap shouldn’t be in a sentence with lowering.
Safe and correct should be the words.
Gotcha. That makes sense.
