Old 12-11-2003, 04:49 PM   #1
nroden
nroden's Avatar
Shift Lever Troubles
This morning was a cold morning with snow from the previous day on the ground.. bad enough already. Then when I put my truck into Reverse something broke. Now my lever is shift lever is real loose and I can only go between drive and neutral. No way to pull back to put it in park or reverse. What happened and how do I fix it???
It is a TH350 automatic.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 12-11-2003, 06:02 PM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
DId the little pin that holds the shifter on the coller on the steering column work its way out?! Mine works itself every once in a while, I just tap it back in. Hopefully that will solve it
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 12-11-2003, 06:41 PM   #3
pickupman
pickupman's Avatar
It sounds like the little ball and pin made onto the gear lever may have broken. I have had that happen before. Pull your lever out and take a look at the end.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 12-11-2003, 06:42 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
I had a similiar problem once. I was going up my stepdad's driveway (if you call it that, more of a boulder-strewn trail ) and i must have bottomed out. Where the shift linkage goes into the transmission, i broke off part of the little C-shaped connector on the tranny side. So the shift linkage slid back off of it and i couldn't shift.
I drilled a hole on the shift linkage pivot point (directly across from where it goes into the tranny), and installed a washer and a nail there so the shift linkage couldn't back off from the tranny...has worked great for like a year so far.
I didn't do a great job of explaining it, just crawl underneat there and you will see what i mean.
Good luck Nick!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-11-2003, 06:51 PM   #5
sactoC10
71 DELUX
sactoC10's Avatar
I thought my lever was never going to EVER get back into place when it was hard shifting for a while, then quit working altogether. I thought I was low on tranny fluid at first, then I realized it was a mechanical matter in the column. Turned out that the sliding mechanism that the lever goes into simply needed to be lubed...nothing else. It was dried out at stuck.
So my point is this...it may be something very simple, just get close in there and look around. Start with the pin, maybe the lever, something in the column...maybe underneath. With enough persistence, you'll find it!
sactoC10 is offline   Reply With Quote
Old 12-11-2003, 09:59 PM   #6
nroden
nroden's Avatar
Looks like pickupman hit it right.
Nick Rodenberg
