05-26-2020, 09:01 AM | #1 |
Vintage Air Blower
I have a Vintage Air System that was installed by a previous owner. the Blower Motor is making alot of noise and I would like to replace it. it appears I may need to remove the hood/Hinge to access the Blower Motor.
Do these systems use the same Blower Motor as what would be used if I went to a parts house and asked for the blower motor for a 67 C10, or will it be different? |
05-26-2020, 09:06 AM | #2 |
Proprietor of Dale's Corner
Re: Vintage Air Blower
Pics will help us identify what you have.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-26-2020, 09:19 AM | #3 |
05-26-2020, 09:30 AM | #4 |
When I replaced my blower fan (motor was fine) I rebuilt the housing so if I ever need to replace my heater core, I can do it without removing the hood hinge or the entire housing. Someday I'll be happy I did.
05-26-2020, 09:30 AM | #5 |
Before you tear into it. Take pics of the firewall under the hood and dash. Post em up
05-26-2020, 09:47 AM | #6 |
I will try and get them this afternoon. All I can remember is there is a a big round spot with a bolt thru the center right behind the passenger hood hinge (I am assuming this to be the Blower motor).
05-26-2020, 10:34 AM | #7 |
I believe what you're seeing is the block off for the stock motor. I think the blower is in the case under your dash.
05-26-2020, 01:51 PM | #8 |
05-27-2020, 06:21 AM | #9 |
I wasnt able to get a pic during the daylight. I hope this is clear enough. Hard to get a pic of the Interior
05-27-2020, 07:47 AM | #10 |
I have never worked on a VA product. But from my understanding it's a stand alone unit under the dash. Are you sure the blower motor didn't suck up a leaf or something.
05-27-2020, 07:52 AM | #11 |
Pretty sure its a bad Blower Motor. it has a really loud squeal and then a few seconds later there will be no air flow.
05-27-2020, 08:00 AM | #12 |
Yep, that sounds bad. Now you need a diagram of how everything is laid out in that case. Hopefully someone who has experience will chime in.
05-27-2020, 10:41 AM | #13 |
Almost Satisfied
If it is a VA system your blower motor is inside the cab. The only picture I have that is close shows it here to the right side. Drops out of the bottom. Mine is an older VA system since I bought it nearly 10 years ago and the truck still isn't completed. It should be pretty easy to get to, but I would pull it out before heading to the parts counter. VA is usually very helpful. Look on their site and I bet you can find instructions and part numbers. Good luck.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
