05-27-2020, 11:43 PM | #1 |
Close up pictures of factory spark plug wire routing
Looking for some close up pictures of how the spark plug wires are ran under the rams horn manifolds on a 1972. I believe there is a clip that goes on the oil pan. Would like to see close up pictures of how all this is routed. Thank you.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
05-28-2020, 12:27 AM | #2 |
Re: Close up pictures of factory spark plug wire routing
I've got some pics of pre and post restoration from a 1972 K20 I restored. Unfortunately, I could only find two pics of the clips on the oil pan. Hopefully these will help some.
Miles |
05-28-2020, 12:33 AM | #3 |
A few more...
05-28-2020, 12:40 AM | #4 |
I found one more pic of the passenger side oil pan clip. This is from a 70 K20. The plug wires for cylinder #2 & #4 should attach here
05-28-2020, 11:19 AM | #5 |
Thank you very much. That’s exactly what I needed. Plug wires are in now. This is why I love this forum!
05-28-2020, 11:36 AM | #6 |
Can someone explain exactly how you are supposed to get the wires through the rubber holders below the heat shielding? I have preformed wires ! I don’t want to cut off one end to fit through the rubber locators.
71 C-20 07 Magnum RT AWD |
05-28-2020, 11:39 AM | #7 |
You can see in this photo what I’m referring to, the wires are not in the rubber locater.
05-28-2020, 12:01 PM | #8 |
I took the holders off, put the wires in them and bolted it back in. Pain in the neck really.
