Old 05-28-2020, 04:19 PM   #1
forestb
forestb's Avatar
Hood Stabilizers
When I adjust my hood so that the front corner hood stabilizers make contact with the top of my fenders it rubs off the paint. How is every one keeping this from happening?
forestb is offline   Reply With Quote
Old 05-28-2020, 07:43 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Hood Stabilizers
If you're referring to the little rubber pads....i have the same thing going on. In fact my truck actually has a divot polished into the metal
AcampoDave is offline   Reply With Quote
Old 05-28-2020, 08:47 PM   #3
forestb
forestb's Avatar
Yes that’s exactly what I am talking about
Old 06-01-2020, 06:41 PM   #4
Southcity
Southcity's Avatar
I'm pretty sure most board members have experienced this problem with their trucks, I have as well. I believe this is because the rubber pads have hardened over time. New ones would probably solve the issue but I have not found them offered anywhere. I'm sure others will chime in with more info.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 06-01-2020, 07:52 PM   #5
forestb
forestb's Avatar
I have bought them in the past but I can’t remember where.
Old 06-01-2020, 08:03 PM   #6
AcampoDave
AcampoDave's Avatar
A friend of mine got them from one of the major vendors like LMC , Brothers or Orange. The old ones were riveted on so we had to cut them off and the new ones were attached with some kind of screw or nut and bolt or whatever. It's been a long time so I don't remember very well.
Old 06-01-2020, 09:38 PM   #7
cwcarpenter98
cwcarpenter98's Avatar
You can get both the front and rear pads from Truckandcarshop. Looks like the rear pads come with new rivets.
I put some new ones on the front of my hood, but the paint had already been rubbed off from the old ones, so I can't say for certain if new ones take the paint off or not
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 06-01-2020, 10:59 PM   #8
forestb
forestb's Avatar
I just saw them on the LMC website
Old 06-02-2020, 10:11 AM   #9
jbgroby
jbgroby's Avatar
There are 4 bumpers on the front of the hood and 2 in the back by the cowl. The two outside corners are factory riveted, and turn hard with age, the 2 by the hood latch are soft rubber and also turn hard with age.
The replacment outter ones are designed to be riveted - but you can use a sheet metal screw to hold in place as the head is countersunk. The 2 for the center just push in place.
Any of the truck places have them see attached pic.
jbgroby is offline   Reply With Quote
Old 06-02-2020, 11:26 AM   #10
forestb
forestb's Avatar
Not to hijack this thread. O wait I'm not. I'm jut getting back to the original question.
How are you all keeping the stabilizers from messing up your paint?
Old 06-02-2020, 11:43 AM   #11
jbgroby
jbgroby's Avatar
The new soft rubber won't mar generally. You'll always going to have some marking no matter simply due to vibration, can't be helped.
Old 06-02-2020, 11:48 AM   #12
forestb
forestb's Avatar
Old 06-02-2020, 12:52 PM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
I wonder if putting 3M clear paint protector there would help?
Old 06-02-2020, 01:09 PM   #14
theastronaut
theastronaut's Avatar
This is what I was going to suggest. You can get small pieces of it on ebay for cheap.
theastronaut is online now   Reply With Quote
Old 06-02-2020, 04:09 PM   #15
jayoldschool
Moderator
Don't over think it. Anything adhesive will work. Electrical tape. Duct tape. Packing tape. Lots of options in varying thickness and colours.
Alternatively, you could cut a disc of aluminum or stainless sheet and glue it to the hood where the rubber hits.
jayoldschool is offline   Reply With Quote
Old 06-02-2020, 05:21 PM   #16
The Rocknrod
Moderator
Or a beer can top, whatever.
Old 06-02-2020, 05:53 PM   #17
forestb
forestb's Avatar
Before I got my new paint I was using a piece of sticky backed felt. It got rubbed out of the the way. So far with the new paint and new front stabilizers. So far no paint has come off but I can see where it is making contact.
Old 06-02-2020, 06:38 PM   #18
The Rocknrod
Moderator
I'm wondering if more hood adjustment would be in order?
And if shimming the hood latch (in the hood) would help?
