Rear disk brakes -- worth it or not?
My truck is a 3/4 ton 4wd, and will be seeing general farm duty, commuter driving, and some heavy towing.
I need to swap the axle under the thing, and there's two routes I could go. #1, use a 1975 14-bolt full-floater axle that's sitting around already. This will need new bearings, seals, and brakes for $350. This axle is equipped with 13" drums. #2, purchase a 2001 14-bolt full-floater axle from the junkyard for $285. This comes with factory disk brakes and a G80 posi-lock. Here too, I'd plan on spending around $300 for new bearings and brakes. The spring pads will need to be moved, but that looks doable enough. Either axle looks like a good deal. I like the idea of disk brakes, because of weight savings and mechanical simplicity. My main concern is that I don't take a step backward in braking performance by switching to disks. I've had quite a few people tell me I would be downgrading, and their credentials indicate they should know. Can anyone weigh in on this?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
| Bookmarks |
