![]() Join Date: Feb 2016
Factory Tach and MSD AL6 connection
There is a grey wire that goes to the Tach i think
I read this but little confusing Any thoughts where to connect when running a factory tach |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Factory Tach and MSD AL6 connection
To a tach filter, then to the tach input wire?
#4 | |
Again i have a factory tach in place |
Moderator
So looking at an online wire diagram (correct part number?). Looks like the red is a power lead and the gray is a tach feed. However there is a red ignition feed.
So my guess would be that the two wires bundled together would be ignition and tach. (The reason I said tach filter is the pulses may not work for the older model tachs. Try it without the filter first then). ![]() If your going points here is the diagram, not sure of your part number though:
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-30-2020 at 09:12 AM. |
#6 | |
Ok so i found this on page 5 of 24 in the instructions. 2 large wires red and black appear to be power feeds. I think i figured that out The small red and grey are the 12v ignition and the Tach trigger wire. Its the grey trigger wire. Where exactly does this connect to?? Last edited by Afirehawk1; 05-30-2020 at 10:44 AM. Reason: Typo |
Moderator
I would think the Tach trigger is what sends the tachometer the pulses that make it read how many RPM there is.
Dont confuse that with a Crank Trigger.
Moderator
![]() Join Date: Dec 2012
There are typically four connections on a tach:
- power - ground - illumination - signal Connect grey to signal. |
| Bookmarks |
