Old 05-29-2020, 06:00 PM   #1
Afirehawk1
66 C10 AAC Wiring Questions
Starting to test out the circuits;
Headlights shift between low and high which is great
Issue is the Bright Light on the cluster comes on either way
What is wrong?
Afirehawk1 is offline   Reply With Quote
Old 05-29-2020, 06:08 PM   #2
wfojon
Chevy guy
Re: 66 C10 AAC Wiring Question - Hi Beam Lite
It sounds like the hi beam indicator is wired before the dimmer switch and it should be after the switch on the hi circuit. It sounds like it is wired to the light switch and is on when the lights are on. As a side note where is the hi beam light in the cluster? My truck never lights up and I haven't really looked for it.
Tehachapi, Ca
57 BBW shortbed
64 C30 service bed
65 C10 long bed fleetside
70 C10 long bed fleetside
74 C30 flatbed
wfojon is offline   Reply With Quote
Old 05-29-2020, 06:18 PM   #3
Afirehawk1
This
Old 05-29-2020, 06:27 PM   #4
wfojon
Chevy guy
Thank you, the DPO of my truck cut the wires off at the fuse box and rewired everything under the dash with one color of wire, white, and spiced everything together, a total nightmare.
Tehachapi, Ca
57 BBW shortbed
64 C30 service bed
74 C30 flatbed
Old 05-29-2020, 06:35 PM   #5
Afirehawk1
66 c10 AAC Wiring - Brake Lights
Ok
Another issue
Turn headlights on....brake lights come on
No bearing on the pedal being depressed or not
Old 05-29-2020, 06:36 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 c10 AAC Wiring - Brake Lights
Just a guess, but I'd say off hand that you didnt wire it correctly.
Old 05-29-2020, 06:37 PM   #7
Afirehawk1
On the wiring everything is new using AAC Harnesses.
Everything is labeled; plug and play
So what could this be??
Old 05-29-2020, 06:40 PM   #8
Afirehawk1
Has to be something else
AAC prelabeled harnesses
Old 05-29-2020, 06:45 PM   #9
Afirehawk1
66 c10 AAC Wiring - Front Park/Turn Lights
In what situations should these turn and off;
Do these only come on with turn signal switch engaged?
I tried that and nothing
Old 05-29-2020, 06:46 PM   #10
jayoldschool
Moderator
What did AAC say?
jayoldschool is offline   Reply With Quote
Old 05-29-2020, 06:48 PM   #11
Afirehawk1
Originally Posted by jayoldschool View Post
What did AAC say?
I haven’t asked them
Assumed someone here could help
Old 05-29-2020, 07:24 PM   #12
wfojon
Chevy guy
Re: 66 C10 AAC Wiring Questions
The hi beam wiring would probably wire into the dimmer switch and be on the hi beam side of the switch so it would only be hot when the hi beams were on. Perhaps you wired it to the hot going to the switch which would light every time you turned the lights on.
Tehachapi, Ca
57 BBW shortbed
64 C30 service bed
74 C30 flatbed
Old 05-29-2020, 09:46 PM   #13
Afirehawk1
Hhm ok
So another question then.
Does the key have to be engaged for the headlights to turn on?
Right now, i can turn them on wo the key.
Which means its tied to the battery and not the ignition Switch? Yes?
Is this correct ?? or have any bearing on the issues above?
Old 05-29-2020, 10:37 PM   #14
norcalcap
Originally Posted by Afirehawk1 View Post
Hhm ok
Im using AAC harness as well. Did a complete rewire....My HL's activate with key off.
About your brake lights coming on with your HL's, are you sure they are your brake lights and not just your taillights? When they are on, and you activate the brake, what happens? Brighter lights or no change? If it is truly your brake lights, then maybe they are simply reversed at the tailight socket or wherever you spliced them together. I did that by accident with my rewire. Just swapped the 2 wires and it worked.
norcalcap is offline   Reply With Quote
Old 05-30-2020, 02:27 PM   #15
Afirehawk1
See if this is correct
May not be
I have 3 brown wires labeled “park lights”.
Do i have it correct or do all 3 wires get tied together??
And slot does it go into?
I do see now i ran the double brown to front parking lights then split side to side
The single brown i ran to the rear lights
If i reverse these at the light switch would this correct my issue
When you look at the AAC diagram i just noticed they have tail light lead and the park light lead reversed in order when u follow the diagram
I will swap these tomorrow and see
Side note. On the hi/li beam switch i still dont see what went wrong; suggestions on this;
Old 05-30-2020, 08:56 PM   #16
notsolo
notsolo's Avatar
The single brown wire on the rt is parking lamps are on in front stay on when headlights are on, factory I think was they were off when headlights were on. Split the 2 brown wires 1 front 1 rear for parking lights. don't use the single wire, unless you want them on in front. Brake wire should be separate color, Light blue. Good ground wires from body to frame and motor? What number is this kit?
notsolo is offline   Reply With Quote
Old 05-30-2020, 09:15 PM   #17
Afirehawk1
Kit 500560
My brake wires are brown, just like the parking.
Lite blue is 3rd parking which im not using
Dk green is right
Yellow is left
Both combo with the brown
Old 05-30-2020, 09:59 PM   #18
ACK
ACK's Avatar
Attached is the '64 light schematic, the light switch harness doesn't look like it's matching your harness. Also, here's some things to try ...
1. Disconnect the light harness at the dimmer switch on the floor. Turn on the headlights, if the brights indicator is on, I'm betting a bulb behind the dash is in the wrong position.
2. Pull the orange wire at the brake lamp switch. If the brake lights are still on, double check the wiring.
Good luck and give updates as you go along.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 05-30-2020, 10:03 PM   #19
Afirehawk1
The AAC Harness is definitely different then stock; the original schematic wont help. I checked the bright light location. It is correct
I will check the brake switch
Old 05-31-2020, 01:47 PM   #20
Afirehawk1
Ok
I removed the floor dimmer harness from the switch And the brake switch harness
1.the head lights will not work and the hi beam indicator is off
2. Rear lights now act funny
A. Driver brake light bright
B. Passenger not on; ground issue? I can take a screw driver and touch the rear socket to one of the housing studs; light comes on very bright like driver side
C. I ohmed the rear wires and everything is ok
3. Could dimmer switch be bad even new with the kit?
4. Dimmer switch connector appears correct?
5. Parking lights i have hanging on the hood but not grounded yet; when I manually ground they turn on
Explain how the orange wire works on the brake switch?
Appears orange runs from fuse panel to switch and also powers the glove box light
the white wire is the 12v from the brake switch
Reminder. My column harness appears to resemble a 63 not like 66
I attached photo of column harness
In this order
Yellow, blue, white, dk blue, pink, purple
Black for horn
Grey for light
So is my steering column harness causing these issues?
Worth replacing?
Old 05-31-2020, 02:37 PM   #21
ACK
ACK's Avatar
Ok
Pressing the brake petal completes the brake light circuit. If one or both brake lights are on with the orange wire disconnected, recheck the wiring, something isn't right. Glove box could be part of the circuit if it's further upstream.
From the looks of the AAC diagram, the brights and the indicator split at the dimmer switch, one light green going to the lights wiring harness and the other to the dash lights. There shouldn't be any other intersecting wires, including at the harnesses, if there are, that should be the culprit. Also can't hurt to check continuity at the dimmer switch just to eliminate the possibility of it being bad.
I'm curious about the 2 brown wires coming out of the "Rear Tail Lamp" pin on the lights harness in the earlier photo. Where does each go, should there be only one wire coming out of it (can't tell from the diagram)?
To combat my ground issues at the bed, I cleaned away paint and rust in a small area on the frame and ran a 12 gauge wire from the frame to one of the bed studs. I also removed both tail light lenses and ran a 4" length of 14 or 16 gauge wire from the bed body to the tail light buckets. Haven't had a tail light issue since.
Old 05-31-2020, 03:01 PM   #22
Afirehawk1
Single brown goes to the parking
Double brown to the rear tail; i will verify
I did ohm the wires to verify from light switch to each end run For both park and tail
Odd the LED brake lights are bright
No change with the brake switch plugged or unplugged
Best way to check continuity on dimmer switch?
The hi-lo beams work when engaged.
Old 05-31-2020, 07:16 PM   #23
Afirehawk1
I also noted this
Back of light switch marked rear lights i have a double Brown park light;
1 of these goes to instrument harness but i didnt run anything from this. This note says park light for dimmer function; only used for digital dimmer
Old 06-01-2020, 04:54 PM   #24
ACK
ACK's Avatar
Most multimeters have a continuity function, it's the symbol below. Unlikely, but possible, the switch has the brights on in both positions and it's just turning the low beams on and off (in effect, you have brights and even brighter brights). If one of the poles has continuity when in both positions, you have your culprit.
For the tail lamps, if you haven't, I suggest disconnecting the harness under the rear bumper and take voltage readings from each of the wires as follows:
1. all lights off
2. all lights off and brakes on
3. running lights on and brakes off
4. running lights on and brakes on
5. running lights and head lights on and brakes off
6. running lights and head lights on and brakes on
If they all check out okay and you have decent voltage readings, you know the harness coming out of the cab is good, so the issue is definitely at the back half of the harness, which makes it much easier. If that's the case, most likely it's one of the following: the wiring and connections to the tail lights need to be reconfirmed; need better grounds to the tail lights; the LEDs don't want to work with 50+ year old technology.
As a side, I'm in the camp of not using LEDs on the truck, with a few exceptions. LEDs have requirements that don't mix with older vehicles, so they have a habit of doing some very odd things.
Old 06-01-2020, 06:21 PM   #25
Afirehawk1
1. all lights off
Update on the Hi Beam Bright light staying on—-
The green and ground were flipped backwards which caused current bleed over.
Lesson on this one
Pix to illustrate
