Old 05-30-2020, 07:39 AM   #1
67chevemall
67chevemall's Avatar
Help tell me what motor I have?
Good Morning.
The only number I can find on the motor without taking the block forward is
K 0 5 0 1 0 GA
Can anybody read this?
I was told it is a 327 but who knows
67chevemall is offline   Reply With Quote
Old 05-30-2020, 07:53 AM   #2
67chevemall
Re: Help tell me what motor I have?
pic
Old 05-30-2020, 08:31 AM   #3
'65 283 from what I found. 3spd manual car. If it's a running engine it's a good find. I'd like to find one
Old 05-30-2020, 08:47 AM   #4
67chevemall
Runs like a top. Just would love to know what I have.
Just dont know what it is and the oil pan is not right because the front two holes are 1/4 inch out. Bolts are not even close to going in
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
Old 05-30-2020, 09:02 AM   #5
uncle
The casting number on the back of the block will give you the definitive answer.
uncle is offline   Reply With Quote
Old 05-30-2020, 10:09 AM   #6
67chevemall
I have tried with every light and mirror I got.
neck is toast for days can't turn it to the right lol
Any tricks? One of them anal cameras be perfect right here.
Old 05-30-2020, 10:09 AM   #7
Cyclone
Cyclone's Avatar
Precisely
Cyclone is offline   Reply With Quote
Old 05-30-2020, 10:21 AM   #8
67chevemall
65 283 car
69 327 impalla car
Old 05-30-2020, 10:22 AM   #9
67chevemall
Harold Saunders would know as he is farting. miss the old boy.
Old 05-30-2020, 12:22 PM   #10
gmc684x4
I would guess and say that is a partial vin from a 4x4 k code not sure if gm used k in other vin numbers
Block casting numbers are at back top of the block
To varify 327 check block casting code and also check crank casting code as well
Example 350 casting code block 3970010 with a 327 casting code crank
You can get either a cheap inspection camera or use cell phone to take pics of the block casting code and depending on casting number further inspection would be needed
Like my bros 327 with 3970010 block casting code its a 350 block pulled the pan and checked the crank casting code next came up 327 truck crank
https://nastyz28.com/sbchevy/sblock.html
https://m.youtube.com/watch?v=5COyGWqJsVE
https://www.mortec.com/location.htm
gmc684x4 is offline   Reply With Quote
Old 05-30-2020, 12:31 PM   #11
uncle
The harmonic balance or is different also. The 283 will have a thinner balancer than the 327. If you can get a picture of it that will probably help someone to let you know what you have.
Old 05-30-2020, 12:59 PM   #12
geezer#99
geezer#99's Avatar
The ‘K’ is the assembly plant.
Look here for that.
https://nastyz28.com/chevy-engine-code-stampings.php
A 65 283 will have a road draft tube hole cast into the block. A 69 327 won’t. Road draft tube hole is beside the distributor.
Old 05-30-2020, 08:25 PM   #13
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I don't know 283, but If that were a 402, I'd think you mean the 1/4" bolts to the timing chain cover, which made little contact to begin with. The original bolts do not work with a one-piece gasket.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-30-2020, 08:40 PM   #14
BigBird05
K St Catherines, Ontario
05 May
01 1st day of the month
Ga 65-283-195 HP-2BBl-3 sp manuel trans
BigBird05 is offline   Reply With Quote
Old 05-31-2020, 06:21 AM   #15
Is it a small journal?
Old 05-31-2020, 10:59 AM   #16
BigBird05
They were all small journals in 65.
Old 06-01-2020, 07:15 AM   #17
You are correct. My question was to confirm if it's a '65 283 or a '69 327. He mentioned bolt holes on the oil pan not lining up
Old 06-01-2020, 06:53 PM   #18
67chevemall
05 May
This is great news! I was born in St Catharines.
65 283 is awesome.
I will try the cell phone picture trick when I can climb back up there.
Thank you guys
