![]() Join Date: Sep 2003
HO52 Rear Drum Brakes Adjustment Hole Exists
There are few old threads that people mention having difficulty adjusting the drum brakes on HO52 rear drums. Like many others, I was hoping to find an access hole on the backside that some other drum brake models have for adjusting the star wheel. But the drums on my 72 don't have any access holes on the backside.
From what I have read it seems like many (maybe all) HO52 drums do not have an access hole on the backside of the drum. However, today, after replacing the shoes and guts, I noticed that my 72 does have an access hole on the front of the drum. Do others have this this hole? Is this common knowledge? I feel like I haven't seen much mention of this hole in the past. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: HO52 Rear Drum Brakes Adjustment Hole Exists
I'm glad (and you are lucky) that your drums have that access hole. Mine definitely do not.
![]() Join Date: May 2010
Mine do, and they are the orginals.
Jim |
![]() Join Date: Feb 2019
Just got new drums for my C20, the drums did NOT come with Adjuster holes, Looks like one of the original drums someone cut and drilled the adjuster hole.
Is it OK to cut and Drill the Drum for the Adjuster Hole??
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
#5 | |
The kit I used to replace my drum parts included a few types of plugs...You might consider drilling the hole in a way that you can plug it with something. |
![]() Join Date: Jan 2009
personally I'd drill a hole in the backing plate so you can adjust with the wheel on. I haven't looked at one of those in a while but it should be possible.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#7 | |
![]() Join Date: Jul 2015
I wonder if you hit those with a drift pin of some kind do they pop out? Thinking this is a possibility, knowing manufacturing they would call it non value added processing. And collect the same money for the part. |
#8 | |
The Older Generation
I have found that trying to punch them out does not work. All you do is beat the crap out of the drum. LockDoc
#9 | |
Steve weim55 Colorado Last edited by weim55; 06-30-2020 at 04:51 PM. |
