Old 05-31-2020, 07:20 PM   #1
mikebGMC70
Gas Pedal cable Question
Dumb question. 1970 C10, I am converting my gas pedal from the rod to a factory cable style found on 71 n up. Question is how much pedal travel do y’all have? How far does it from the floor when not pressed?
mikebGMC70 is offline   Reply With Quote
Old 05-31-2020, 07:25 PM   #2
Sheepdip
Sheepdip's Avatar
Re: Gas Pedal cable Question
Just enough for full throttle.
Sheepdip is offline   Reply With Quote
Old 05-31-2020, 09:11 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Gas Pedal cable Question
Here are some pictures of the ones I have. The first one is the Lokar pedal upgrade in my 71. The other is the 68 step I installed the 71 factory pedal in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-14-2023, 01:27 PM   #4
ghackett1
68 C10 Longbed
ghackett1's Avatar
This an older post but from the picture in the 68 it looks like there is a lot more travel with the newer cable set up. Is this a correct assertion?
Asking because my 68 pedal non cable original style moves the carb lever fully but has almost no travel. Just doesn’t have the right feel. I prefer more travel. ANYONE?
ghackett1 is offline   Reply With Quote
Old 03-14-2023, 01:29 PM   #5
ghackett1
68 C10 Longbed
ghackett1's Avatar
Here is the pic from previous post I was referring to:
