Old 06-01-2020, 03:09 PM   #1
Jscompto
Stock dually wheels - what is the biggest tire you can use?
Hey everyone,
I'm sure this has been discussed over and over...but I have a 79 C30 that I converted to a K30. I need to get tires for it and I am wanting to know what tire sizes will work. The tires on it now are 215/75/16. I'd like to go with a wider and taller tire, but I'm not sure how wide or tall I can go without having issues. There's no lift on the truck and I just installed a Dana 60 front axle. Just wanting to make sure I know how wide and how tall I can go before I buy tires. Thanks in advance and I appreciate the help!
'79 GMC C30 C&C dump truck converted to K30
'69 Chevy C30 C&C dump truck with 11,000 lb rear axle and 10 lug hubs
'90 Chevy S10 Baja edition, regular cab with 73k miles
'93 Chevy S10 2WD, 4.3, Auto
Jscompto is offline   Reply With Quote
Old 06-01-2020, 03:20 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Stock dually wheels - what is the biggest tire you can use?
Make sure your tires dont run each other and your good...
I have 235/85r16 on mine...they are really close to touching..I've been thinking about adding a 1/4" spacer between my rims for good measure...but I dont like using spacers...
When I'm loaded down is when it's the closest
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-02-2020, 02:22 PM   #3
Jscompto
Mine will have a dump bed on it. But I also have helper springs too...so it's going to have some weight to it. Maybe a 235 would work...
Old 06-02-2020, 10:04 PM   #4
Mike C
Mike C's Avatar
I have 235 85 16 on my '86 K30 and that's probably max without spacers. They work well IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-03-2020, 08:58 AM   #5
sweetk30
sweetk30's Avatar
255/85/16 is a 33" tall super skinny .
235/85/16 is the 31.3" or so tall .
215/85/16 is the shorty .
and any DRW that needs a spacer you should run the spacer with a hub centric ring built in to it to center the outer DRW rim . the DRW rims are HUB centered and NOT lug nut centered . if you move the outer wheel out you move it off the hub face that centers the rim up .
also if you have the narrow c&c rear the tire cant be to much fatter or it will rub the leaf spring pack . my pics later will show how close .
i got pics of the 255/85/16 on my old truck i will post later when i get home .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-03-2020, 03:33 PM   #6
Jscompto
Yeah, definitely show me some pictures if you're able to! The 215's I have now just seem small on the truck. I need 3 tires so I may just get 6 and want to have them all the same. I definitely don't want to use any kind of spacer, which is why I asked the question on the tire size. I remember my buddy using some kind of spacers back in the day and he ruined something on his truck.my main goal is to have a bigger, taller and slightly wider tire without having issues on the tires
Rubbing each other with any kind of weight on them.
Old 06-03-2020, 04:40 PM   #7
mongocanfly
Post Whore
My 235s have about 1/8" between them...it had 7.50sx16s on it before and it looked like you could stick a finger between them
A do-over and I would go with a 225 or 215
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-03-2020, 05:42 PM   #8
sweetk30
sweetk30's Avatar
here is 255/85/16 on a k30 C&C flatbed with a empty bed .
these were cooper stt if i recall . i went a different direction . swap to srw and 35" tires .
