06-02-2020, 07:33 PM | #1 |
ocm fuel pump wire
I am wiring my fuel in tank fuel pump thru a relay . Is the wire from the engine harness a ground or a power wire? need to know what side of the relay to hooks up to. I am assuming it is a power wire
06-02-2020, 08:39 PM | #2 |
Re: ocm fuel pump wire
On the after market LS harnesses I've used they supplied a 12 volt wire to the fuel pump. The LS ecm supplies the ground to the fuel pump relay I believe.
06-05-2020, 04:58 AM | #3 |
The PCM supplies 12v to the fuel pump relay to turn it on.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-05-2020, 04:25 PM | #4 |
I think the older LS computers like before 2006 supplied the ground to the relay. After 2006 when they went to the 58 tooth crank the computer supplies the 12 volt.
I may be wrong. I'd ask the question over on LS1tech.com. Those guys over there are pretty good. |
06-05-2020, 08:51 PM | #5 |
ls1nova71 is correct. The PCM provides 12v to the fuel pump relay. That is true for both the 24x and 58x systems.
06-05-2020, 10:43 PM | #6 |
chevy truck fan
are you asking about on the factory harness? I have a '13 4.8 LS with all the factory "x" connectors (underhood fuse box). the fuel pump conn. wire is grey and same gauge as the pink wire from my '86 truck. I think these 2 wires will splice together & then go back to the pump? ... I think?? LOL!! If you have a aftermarket harness I think the directions will tell you how to connect the wire.... hope this helps....
....good luck!! |
06-07-2020, 11:26 PM | #7 | |
So when the key is turned on (switched) the fuel pump becomes (relayed) hot with 30 and 87 to the pump So I am to believe that the ECM supplies the 12vdc with the key on or does it just get a switched 12vdc with the key on
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
