Old 06-02-2020, 08:01 PM   #1
kglowacky
relay box
Help . I am wanting to buy a aftermarket relay box with a fuse strip built in it for both my fuel pump and cooling fans.. I have been told for the fuel pump I need a 4 pin 30 amp. I am assuming for the dual cooling fans I will need the same. My question is everyone seems to want to sell me a 5 pin relay not a 4 pin. . Ebay has a great bare box but I am trying to buy the complete system (Relays and fuses included) as my wiring knowledge is little. Anyone have a source for this. I seen the box and relays on another thread and love the way they look. Thanks
kglowacky is offline   Reply With Quote
Old 06-02-2020, 08:14 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: relay box
is this for a LS engine?
for elec fans I use relays from PSI..https://www.psiconversion.com/produc.../KIT-1010.html
youll need a separate relay for each fan to run them independent
they also sell a diy relay fuse kit that's 40Amp...https://www.psiconversion.com/produc.../KIT-1023.html
but all my fuel controls are in the fuse block for the engine wiring harness on mine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-02-2020, 08:47 PM   #3
kglowacky
Re: relay box
Thanks I am looking for a box that will hold 4-6 relays so I can mount one unit to the side fender and run all my relays from it.
Old 06-02-2020, 09:12 PM   #4
TrybalRage
Re: relay box
I’m putting my stuff together using this guy: 12V Auto Waterproof Fuse Relay Box Block [6 Bosch Style Relay Holder] [6 ATC/ATO Fuse Holder] Universal Relay Block Box for 12V Automotive Vehicles Cars Marine Boat Jeep Light Equipment https://www.amazon.com/dp/B07MR64XK1..._IIV1Eb3M6QCA2
Yes it uses 5 pin relay, but you just wire 4 of them up. Two for the switched power, and two to carry the load to the fans. There tons of images and stuff online, I’ve had to do a lot of reading myself.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
TrybalRage is offline   Reply With Quote
Old 06-03-2020, 08:55 AM   #5
kglowacky
Re: relay box
That is the one I got my eye on. just wasn't sure if the 5 pins would work using them as 4 pins. Thanks
Old 06-03-2020, 11:07 AM   #6
TrybalRage
Re: relay box
My only real criticism is that the fuses don't have a positive buss, so each has to be wired separately or with jumpers. Kind of a pain.
Old 06-03-2020, 04:15 PM   #7
kglowacky
Re: relay box
been told to use 30 amp relay on fuel pump what amp is everyone using for cooling fans, I am using a set of fans out of a 2005 dodge advenger. it looks like oem 12 gauge wire coming from them. Also going to put a fuse
inline for each relay does it go before the relay or after or does it matter. Thanks
Old 06-03-2020, 04:32 PM   #8
mongocanfly
Post Whore
Re: relay box
on my psi harness fuel and fans all use 30a relays
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-03-2020, 08:18 PM   #9
nsb29
nsb29's Avatar
Re: relay box
You can use 5 pin relay you gust don’t use pin 87a if you’re using 3 relays for your fans you need 5 pin
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-03-2020, 08:51 PM   #10
plumber452
Re: relay box
Here is the one I used worked great https://www.bp-automotive.com/produc...rness-mod-kit/
plumber452 is offline   Reply With Quote
Old 06-03-2020, 08:51 PM   #11
kglowacky
Re: relay box
thanks that explains alot
Old 06-04-2020, 08:20 AM   #12
C.I.Blazer
Re: relay box
I am in the process of doing the exact same thing but a making my own relay fuse panel. This is an in-process pic so obviously I am not finished wiring up all the connections. The fourth fuse on the fuse block is being used for my headlight relay mod. All the parts are available on Amazon and were pretty cheap.
Cannot take credit for any of this as I am just copying what Nich has done on his great build. Here is a link to his thread http://67-72chevytrucks.com/vboard/s....php?t=737560m He also has some really great videos on You Tube.
Hope that helps.
C.I.Blazer is offline   Reply With Quote
