Old 06-03-2020, 01:01 AM   #1
chev-obsession
chev-obsession's Avatar
U Joint Help needed
To make a long story short, I had my front driveline shortened which lead to rebuilding it. (Lesson learned pay the money and have the pros do it) now that we’ve got that out of the way, the shaft that came out of the truck is for a 69 Chevy c 10 with the 4 speed. I lost the caps some how so I cannot take anything in and compare it before I buy.... lessons being learned all over the place.
I got u joints from Napa and of course their the wrong size. Have a spare shaft that I believe came out of an automatic truck to compare mine, the u joints are significantly different. I’m not sure the the shaft in the truck that I had shortened is original to the truck which if that’s the case then I’m not sure what u joints it it is that I’m after.
Trying to find the right u joints, have you guys ran into this? Do you know what size, or a part number might be for the correct u joint? Here’s a few pics, looks like a p/n 3707775.
Any help is greatly appreciated
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 06-03-2020, 01:14 AM   #2
chev-obsession
Re: U Joint Help needed
Here are the pics, the big joint I’m looking for is 3 7/8”
1965 c/10 swb
1969 c/10 lwb
Old 06-03-2020, 09:59 AM   #3
sick472
sick472's Avatar
I'm no U-Joint expert, but this page should help you determine what you need...
http://knowhow.napaonline.com/know-h...u-joint-guide/
Be aware that there are u-joints that adapt from one size to another. Make sure you measure both yolks to make sure you don't need a combination u-joint...in case a PO has done something squirrelly.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-03-2020, 10:11 AM   #4
OregonNed
OregonNed's Avatar
I just did this project (new U Joints) and that reference page is the best guide. Making the measurements, I found that I have the very common 1310 type. I went with non-greasable Spicer joints - very happy with how it turned out..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-03-2020, 10:12 AM   #5
Sheepdip
Sheepdip's Avatar
Your driveline rebuilder can help you or look here:
http://67-72chevytrucks.com/vboard/s...90#post8746090
Sheepdip is online now   Reply With Quote
