Old 06-05-2020, 03:12 PM   #1
King16
2007 L94 out of Escalade.
Has anyone used one of these motors in a 67 c10? looking to get 600-800 hp out of it. Should this be a straight forward install or am I opening up a big bag of worms? Also will a turbo 400 bolt up to this motor?
King16 is offline   Reply With Quote
Old 06-05-2020, 04:42 PM   #2
gmc684x4
Re: 2007 L94 out of Escalade.
It should fit fairly well
Many ppl have put ls engines into our trucks
Turbo400 will bolt up needs a different flywheel
Why not use the 2007 overdrive tranny ?
Here is anouther thread with many answers on this and questions that come up
http://67-72chevytrucks.com/vboard/s...d.php?t=716372
gmc684x4 is offline   Reply With Quote
Old 06-05-2020, 06:03 PM   #3
MDPotter
MDPotter's Avatar
LS swaps are done all the time. Maybe a mod will move this to the LsX swap section for better responses. No reason to use a TH400 though - you're better off using the trans that came with it or find the same one that should be behind it.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 06-06-2020, 02:23 AM   #4
King16
I would use the same trans but seems to be geared toward gas mileage and not performance. Is there a way to retune the shift points
Old 06-06-2020, 03:39 AM   #5
gmc684x4
Yes the tranny is tune able either your self or by a tune up shop should be able to change it to a more streatable tune and have overdrive for the interstate
http://www.lt1swap.com
You can email the fellow at lt1swap and ask him he is a valued resourse
Old 06-06-2020, 01:52 PM   #6
weq92f
weq92f's Avatar
Flip fa ya...
That motor is pretty hot in stock form... curious how you gonna bring it up to your target HP level...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-06-2020, 04:46 PM   #7
LS short box
To get 600-800 hp out of that engine a turbo or super charger will be needed for "streetable" performance.
I've done a couple 2010-2012 L92 6.2 engines and with a medium cam (225I 232E) they made 425 hp on the chassis dyno so about 500 hp at the crank. Both drove very nice on the street and easy to tune.
The trans can be tuned to whatever shift points you like. Same with the converter lock up. Buy a good billet converter like a Yank or Circle with a 3200? stall and it will really wake it up off the line.
LS short box is offline   Reply With Quote
