Old 06-06-2020, 11:38 AM   #1
5Tractorguy
5Tractorguy's Avatar
Door seal weather stripping and lug nut Q's
I'm going to be replacing the door to cab weather stripping on my '79 C30. Noticed that a good portion of it is glued onto the cab. What sort of glue/sealer should I use to reinstall?
An since I'm here, anyone have a good source for chrome or zinc plated lug nuts? I painted them white with the wheels, but running 'em on with the impact chips the paint off of course, and it's a pain to do touch up.
Jake
5Tractorguy on Youtube
5Tractorguy is offline   Reply With Quote
Old 06-06-2020, 12:12 PM   #2
Axle
Axle's Avatar
Re: Door seal weather stripping and lug nut Q's
I keep an eye on amazon, last time I got a box of 100 bulk packed McGuards for ~$46cdn.
Alex.
Axle is offline   Reply With Quote
Old 06-08-2020, 07:13 AM   #3
5Tractorguy
Bumping this up folks... Anyone have any info on the door weather strip?
Jake
Old 06-08-2020, 07:58 AM   #4
truckin 79
I just installed 1A Auto weatherstrip kit in my 79 C10 from EBay. The window felts do not need glue or at least I didn’t use any. It is a nice tight fit and does not seem to need glue to stay in place. I will say that the felts are tight everywhere except maybe around the door lock area. I also put window tint as well because sun was beating up interior. If you are talking about outer rubber door seal that is just a press fit around door edge no glue needed there either. Was a easy install and it was 100 for new seals
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-08-2020, 08:20 PM   #5
Big Chip
Big Chip's Avatar
Are you talking about the secondary seal that is glued to the top of the doors? If so you could try 3M 1300. You can get that just about anywhere and brush it on with an acid brush.
Big Chip is offline   Reply With Quote
Old 06-09-2020, 08:34 PM   #6
5Tractorguy
This is the seal I'm referring to guys. Should've posted a picture before... It's glued all along the front edge where the arrows are to about the middle up top. Where it comes down the back side isn't. I wasn't sure if it needs to be glued because water might run in between where the weather strip presses on the metal edge (if that makes any sense).
Name:  Screen Shot 2020-06-09 at 8.27.23 PM.jpg
Jake
Old 06-10-2020, 12:01 AM   #7
SunSoaked
SunSoaked's Avatar
No glue on that deal. Snaps into place with embedded clips.
SunSoaked is offline   Reply With Quote
Old 06-10-2020, 08:33 AM   #8
Pontiac1976
Pontiac1976's Avatar
Those have been glued some time if the old rubber will not stay in place people getting tied of them pop off. But new rubber should work for a long time with out glue.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-10-2020, 10:27 PM   #9
5Tractorguy
Thanks Folks! Now I can finally get the last bit of the floor mat done once the seals are in.
Jake
