06-06-2020, 12:44 PM | #1 |
Radiator support bracket mount
looking for a source for the rubberized frame mount the radiator support bracket bolts to. 1965 Suburban.
06-06-2020, 01:11 PM | #2 |
Re: Radiator support bracket mount
06-06-2020, 03:44 PM | #3 |
This is what I'm looking for
06-06-2020, 05:01 PM | #4 | |
Moderator
Yep, those are the ones.
Yes even parts suppliers.
06-06-2020, 08:46 PM | #5 |
Not even close.
06-06-2020, 09:17 PM | #6 |
Are you asking about the piece that is riveted to the frame? I'm not sure if that piece is avaliable
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-06-2020, 10:05 PM | #7 |
60-66 Nut
The Suburban/Panel radiator support mounts are not reproduced and last I heard, Steele Rubber was not setup to re-vulcanize them.
06-07-2020, 02:36 AM | #8 |
Thank You Captainfab, that is the info I was looking for. The rubber on mine
have just started to crack at the top and have some life left in them. Hopefully they will be available sometime in the future. I'll email Steele Rubber and put my name on the waiting list. |
06-07-2020, 08:43 PM | #9 |
