Old 06-06-2020, 04:28 PM   #1
cgster
Replacing rad support bushings
Fixing to take my front panels off so I can replace the rad support bushings. How hard are they too replace? Any spot welded bolts I need to deal with?
cgster is offline   Reply With Quote
Old 06-06-2020, 07:39 PM   #2
BigBird05
Re: Replacing rad support bushings
The hardest part is getting the old Rad support bolts. You might ( probably will) need new ones.
BigBird05 is offline   Reply With Quote
Old 06-07-2020, 12:01 PM   #3
tdangle
tdangle's Avatar
When I changed mine out, it was really easy. Just had to remove the radiator.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 06-07-2020, 01:51 PM   #4
weq92f
weq92f's Avatar
I was able to do it without fully removing the radiator. Just removed the top rad supports and then gently shifted the rad over for each core support bushing swap.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
