![]() Join Date: Sep 2019
Fuse Block Bulkhead Repair
Hi everyone,
I am having a had time (read: unable to) locating the engine, light, and rear light harness bulkhead connectors and pins for the fuse block (engine bay side of the firewall connection). I do not have any issues but I want to build replacements while I keep the truck operational. Any leads?
Mike 1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop Obligatory Build Thread HERE! 1979 C20 RCLB - 350 - TH350 Auto |
Re: Fuse Block Bulkhead Repair
I figured they're just common female Packard-56 terminals. Do these look right?
https://www.amazon.com/s?k=packard+56&ref=nb_sb_noss_2
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
![]() Join Date: Dec 2009
Are you looking for the connector like this?
Here's the fuse block its attached 2 below for reference. This is an 1981 C20
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Moderator
![]() Join Date: Oct 2008
The bulkhead plug is Packard 56 & Packard 59 terminals like you linked.
The ATC/ATO fuse panel is mostly filled with Pak Con terminals along with a few Packard terminals for things like the flasher relays. The only ones that get exciting are the ganged or bussed, depending on what you want to call them, Pak Con terminals in the fuse panels. .
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I'm out of town so I cannot post any pictures.
I am looking for the housing for the packard connectors on the engine/headlight harness side. The bit that plugs into and presses in with the center bolt into the fuse block.
Moderator
Assuming this is for the 1979 C20 since the stock fuse panel is AGC glass fuses in the 1976.
The Male Packard 56 terminal forward lamp bulkhead plug is the obsolete Delphi Packard 8917233 https://www.mouser.com/catalog/specs...g_08917233.pdf It should be fairly straightforward to release the terminals from this plug and insert new ones as long as it's not damaged. Male terminals are a little more difficult to release than female but it can be done with a pair of needle nose pliers and some patience. If it's chewed up or melted you can get this out of a range of GM vehicles from 1979 through the mid 1980's at least.
wixthedog
If your interested I will give you these for the cost of shipping. 1 was missing from the truck when I bought it, but the other 2 are ok. Here's 2 pics below Send me a PM if your interested. Again there from a 1981 C-20 .
#8 | |
That is a very nice offer, thank you. Depending on what Hatzie says above I will take them if they are the same for a 75/76 model.
The break down In mid year 1980- 1981-87 are different from the, 73-79 front half of 1980 for the bulkhead. As 81-87 they when to plastic blade type fuses. As 73-79 they where glass type fuses.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
This is a picture of the harness connector from a 1977 k20.
It has glass fuses. It looks very similar. I could compare the terminals if you need me to. Do you have a Pick a part junk yard near you? If so you could probably get the whole thing there. Here's the picture of 77 with glass fuses .
Moderator
The part numbers for the bulkhead plugs are in the wiring diagrams.
1973 & 74 used a smaller bulkhead plug than 75 & later. 1975-1986 CK P & G and the 1987-1991 RV P & G chassis used the same bulkhead plug for the lights. Probably many of the GM fullsize cars as well. Mid 70's on B Bodies like the Caprice, Impala, Parsienne, etc are likely donors and probably the G bodies and even the X bodies.
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-10-2020 at 11:04 PM. |
Thanks guys, you always come through with help and assistance when asked.
I think I will hold off, eventually I plan on getting a new fuse block so I might as well tailor it all to mesh when that happens.
#13 |
Moderator
If you're dead set on updating the wiring get the cab harness from a 79-82 with the plastic ATC/ATO fuses.
Download the wiring diagrams for the donor and the 76. You can re-pin the 76 engine bay plugs to mate with the later bulkhead plug. IIRC there are only a few differences. The heater/AC and dual tank wiring will plug directly into the new harness. Your 76 wiper motor is wired differently from the 78 and later but you'll be able to put delay wipers in if you want them.
#14 | |
| Bookmarks |
