HEI clearance
If I switch to HEI are there any clearance problems? I know there is room once installed but, on my BB when putting in the points dist the rotor had to be removed to squeek it in.
i think hei is a little taller than a points type setup if it has the build in coil but i really dont know.
70 longbed 496/th400/Ford 9" |
Formerly yellow72custom
HEI is taller and wider. No clearance problems on a SBC installed in the correct V8 position, but i dunno about big-blocks....
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
![]() Join Date: Aug 2001
![]() NO CLEARANCE PROBLEMS AT ALL. SMALLBLOCKS IN THE 6 CYL. POSITION WILL CLEAR THE FIREWALL JUST FINE, ALTHOUGH YOU DO HAVE TO REMOVE THE CAP FIRST. BIG BLOCKS IN THE V-8 POSITION & ALL MOTORS IN 4WDs FIT GREAT TOO. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() Join Date: Dec 2002
installed GM delco HEI dist on my 402.BB... no clearance problems............ JIm
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
