12-12-2003, 01:20 AM | #1 |
Will 8" rallys rub ?
I was hoping to run my 8" rallys for the summer because I don’t have a lot of extra money for rims. I will eventually get 17" all around but right now I just want to get it on the road. So what I have is a 2.5 drop spindle and a 1" coil. I am worried about rubbing problems. What tire size should I run? I want there to be a bit of side wall if possible. Just looking for opinions and for the guys out there who have run this setup.
I don't want to rub off My new gloss Black paint on my inner fenders either. Thanks Mario
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-12-2003, 01:31 AM | #2 |
Formerly yellow72custom
I don't think they will rub but a can't say for sure.
A good tire size is 255/60-15. They look great on an 8" rallie. Or even 275/60-15 if you want them a little bigger.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
12-12-2003, 01:37 AM | #3 |
I want a huge tire on the back. I am going to need all of the traction I can get. I was thinking of a 295 for the back.
12-12-2003, 01:38 AM | #4 |
im running 255/60-15's on my truck.
i think the wheels are wide though--- putting it on a not so wide wheel will make it not so wide
70 longbed 496/th400/Ford 9" |
12-12-2003, 01:40 AM | #5 | |
12-12-2003, 03:36 AM | #6 |
My other Love
im running 15/8 stock rallyes with 265's all around with no problems and that is with the front lowered 2.5 inches
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
12-12-2003, 03:36 AM | #7 |
My other Love
12-12-2003, 04:30 AM | #8 |
I have never had tire rub. Even when I am turning A corner and pulling A curb at the same time. I want A 4/6 drop. and I will use the same combo And I would say that I wont have A problem with rub.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
12-12-2003, 05:41 AM | #9 |
Re: Will 8" rallys rub ?
[QUOTE]Originally posted by 72MARIO
[B]I was hoping to run my 8" rallys for the summer because I don’t have a lot of extra money for rims. I will eventually get 17" all around but right now I just want to get it on the road. So what I have is a 2.5 drop spindle and a 1" coil. I am worried about rubbing problems. What tire size should I run? I'm running a 255/60/17 on the front of my 72 with a 3 inch drop and not seeing any problems with rubbing, mine hits the bumpstops before it will rub
PR Too many projects, not enough time! 72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold! 69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam. 78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's 77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs |
12-12-2003, 07:22 AM | #10 |
Watch out for your cornhole !
I'm down 4.5 inches in the front with 8 inch rally wheels. Tires are 245/60/16 front and 275/60/15 rear.
You will not rub with a rally. My truck had a 6 cylinder in it in this picture, so it's not too low. Big block swap this month will lower it some more.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 12-12-2003 at 07:25 AM. |
12-12-2003, 11:24 AM | #11 |
I was planning on taking my rear rims to a Race Shop. They will widen the rims up to a 15" wide for 150 dollars. I think it would look pretty cool.
12-12-2003, 12:26 PM | #12 |
You shouldn't have any problem running 295/50-15's with your drop...but you need 10" wide wheels. Kinda hard to see....
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
12-12-2003, 03:10 PM | #13 |
i am running the BFG drag radial 325-50-15's on 15x8 rallys with at standard backspacing. i do have a small 1/8 spacer place for a little extra space. it will work. i run my truck at IRP here in indy.
12-12-2003, 03:20 PM | #14 |
pics?
12-12-2003, 06:18 PM | #15 |
Low & Slow
I didn't see this earlier but, I have 2.5" spindles 1.5" springs and 8" 4x4 rallies on mine, I also have 255/60/15 bfg's on the front. It does not rub at all. Like said before, It will hit the bumpstops before it rubs.
70' C-10 LWB Fleetside 4.5/6 drop |
