06-10-2020, 02:41 PM | #1 |
Is this too low for the steam port connection?
I already had the threaded bung in my radiator so I thought I would run my steam line to it. Now I am thinking it may be too low on the radiator to be effective.
So, is this okay or not? Thanks. |
06-10-2020, 04:30 PM | #2 |
Re: Is this too low for the steam port connection?
I think you will be fine. Some tap the water pump for the steam line and that's lower than your setup.
06-10-2020, 04:53 PM | #3 |
Post Whore
Correct ...I have mine in the waterpump and it's at least as low as yours...if not lower
06-10-2020, 05:04 PM | #4 |
Moderator
That will be fine...that port is usually where the temp sensor for the fans is installed...
Where is your fan temp switch located?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
06-12-2020, 11:46 PM | #5 | |
https://www.jegs.com/i/Derale/259/66826/10002/-1 |
06-13-2020, 07:55 AM | #6 | |
Moderator
Follow the install location recommendations.
