06-11-2020, 12:16 AM | #1 |
Not sure what is wrong with the brakes on my 1968 Chevy C10
The brake pedal on my 1968 Chevy is very,very,very mushy and I can push the pedal all the way to the floor with very little effort and it doesnt stop the truck until you floor it.
It Feels like there is still air in the system although I have bled the master cylinder twice while off the truck and I tried bleeding the system with no success. I then took the truck to a local shop and they couldnt fix the issue either. Here are the modifications that I have made to the brake system on my 1968 Chevy C10 fleetside short bed. I converted it to 4 wheel disc brakes. All parts are brand new. The truck originally had 4 wheel drums. *Front disc brake kit from Early Classics *Tuff Stuff 9 inch booster TFF-2224NB *Tuff Stuff brake booster rod and clevis kit #4750 (replaced stock rod) *Master cylinder for 1975 Corvette *Summit Racing GM prop valve for 4wheel disc system #760185 *Rear disc brake kit from Captain Fab that uses 76-78 Cadillac Eldorado calipers with built in e brake levers and rotors from 92-02 Chevy Astro AWD van I am getting fluid from all four calipers,bench bled master cylinder twice and bled system numerous times with no success but each time it seemed like the system didnt have any more air in it as I wasnt getting bubbles anymore. Again also took the truck to a local shop which I dont think the tech was very knowledgeable and he was not able to solve the issue either. Any suggestions on what might be causing he issue? |
06-11-2020, 03:03 AM | #2 |
Re: Not sure what is wrong with the brakes on my 1968 Chevy C10
Just a couple fairly obvious suggestions you probably already eliminated...
Make sure all bleeder screws are facing up. People have managed to install calipers wrong. Bleed the longest line first and the shortest last. |
06-11-2020, 04:42 AM | #3 |
I read that it is a powered brakes. Was it originally manual brakes?
06-11-2020, 10:41 AM | #4 |
Who Changed This?
Did you adjust the rear calipers? They need the space, if any, taken out. That's different from the front.
06-11-2020, 11:04 AM | #5 |
Do you have the correct size master cylinder? Is the booster pushrod adjusted to the correct length? Is the pushrod in the correct hole in the brake pedal assembly?
Here's a link to CPP's troubleshooting: classicperform.com/TechBook/BrakeTroubleshoot.htm
72 C10 lwb fleetside -stock 350/350 combo |
06-11-2020, 12:40 PM | #6 |
Look over all lines looking for leaks
06-12-2020, 07:07 AM | #7 |
Sounds like a bad master cylinder.
06-12-2020, 08:13 AM | #8 |
laying low
I had the same symptoms. Adjusting the push rod between the master cylinder and booster removed much of the pedal travel from my 69 stock system. I have a good pedal now.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-12-2020, 09:14 AM | #9 |
2X on adjusting the rear brakes. the combo valve might not be holding any pressure on the rear calipers.
06-12-2020, 02:18 PM | #10 |
Yes all bleeder screws are pointed up and I have tried any and all bleeding methods.
06-12-2020, 02:20 PM | #11 |
06-12-2020, 02:23 PM | #12 |
06-12-2020, 02:27 PM | #13 | |
I will post a pic of the hole I am using. I have full pedal travel but it is mushy. Not sure what else to check as far as the booster pushrod beind adjusted to correct length? |
06-12-2020, 02:28 PM | #14 |
06-12-2020, 02:29 PM | #15 |
06-12-2020, 02:31 PM | #16 |
I dont remember the booster rod between the master cyldinder and the booster being adjustable at all on this particular Tuff Stuff booster.
06-12-2020, 02:33 PM | #17 |
06-12-2020, 02:34 PM | #18 |
I appreciate all the responses and I can now start checking on these things to make sure everything is in order!
