Old 06-11-2020, 02:03 PM   #1
oldrustytrucks
Repop bed floor / wheel tubs VS Original
Curious how the repop (steel) bed floor and wheel tubs (specifically Dynacorn) compare to OEM? I understand nothing beats an original but these 50 year old parts are hard to find without issues. Really want to know how fit and finish is and if metal thickness is comparable to original. Thanks in advance!
oldrustytrucks is offline   Reply With Quote
Old 06-11-2020, 04:47 PM   #2
LS short box
Re: Repop bed floor / wheel tubs VS Original
I did a wood floor with every thing else was reproduction. The wheel tubs bolted right up to the bed sides. Didn't have to slot anything.
LS short box is offline   Reply With Quote
Old 06-18-2020, 08:42 PM   #3
oldrustytrucks
Anyone?
Old 06-18-2020, 10:04 PM   #4
tim71
tim71's Avatar
I put a repop entire floor in my 71K1500 during the build back in 2016. Surprisingly, it fit very well. Only issue was a little massaging to get the under bed original mud flap looking piece bolted back correctly on both sides (holes not lining up right). I replaced the bed floor due to waviness of 45 years of use, not rust issues. I put in new aftermarket wheel tubs also. I purchased everything from LMC truck. Bed floor was 100% complete with cross rails and end rail. Expensive but I was very satisfied with end result. Not sure what vender LMC was using in 2016.
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 06-18-2020, 10:06 PM   #5
ss454conv
I used a repo steel floor, wheel tubs and front bed panel with my original bedsides and tailgate. I was very pleased with the fit and finish. I have no problem recommending them. I believe mine were Tri Plus but I am not positive. It has been 3.5 years since I purchased them.
ss454conv is offline   Reply With Quote
Old 06-29-2020, 07:49 PM   #6
oldrustytrucks
Thanks for the info!
Old 06-29-2020, 08:13 PM   #7
samkost
samkost's Avatar
My experience with the after market bed wheel tubs was they took some work to iron out the flange lips. I sent this set back because of poor stamping.
The next set was a little better but still needed a little minor massage work.
samkost is offline   Reply With Quote
Old 07-03-2020, 09:12 PM   #8
oldrustytrucks
Good info, thank you
Old 07-04-2020, 12:16 PM   #9
Toro
Toro's Avatar
I just replaced the wheel tubs on my 72 Blazer. I’m not sure of the brand, there were stickers, but just with part number. I don’t know how many manufacturers are re-poping these.
My only “problem” was that when the fender side bolts were tight, the floor flange was about 1/2” from the bed floor. I ran each bolt/nut just barely on all around, and then went back and pulled everything tight. This made it a little trickier keeping my seam sealer from going everywhere, but as with everything, the second one went on easier than the first.
Toro is offline   Reply With Quote
Old 07-05-2020, 01:14 AM   #10
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
The Woodall floors are spot on. I bought one for my GMC and I have had no issues. Very well done.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-10-2020, 06:06 PM   #11
oldrustytrucks
Thanks guys!
