another grille paint color question
So based on the image below, I went and got some "correct" dark argent paint for the grill for my 74. Except now that I've gotten it, I'm not entirely sure how correct it is. It's pretty dark. In the sun it shines pretty good and looks lighter, but I'm not sure if it's right. It seems like any remaining paint on my grille is much liter and more regular argent.
I have done a ton of searches on here, but haven't heard anyone using the dark argent with the "correct" paint code. Is the inner section of the grille darker than the outer "ring"? Not sure what's going on here. Thanks. |
Re: another grille paint color question
Hum grill headlamp bezel = trim around the headlight( all so know as headlight doors) the pocket around the head light is dark argent ! as your pic show. They came dark argent, gray, black depending truck option.
and the center upper grill would be argent to light come pared to the grill headlamp bezel = trim around the headlight( all so know as headlight doors) the pocket around the head light is dark argent ! https://www.youtube.com/watch?v=ttPHaURPSaY
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 06-15-2020 at 10:14 PM. |
#3 | |
Edit: I ask because the colors they are specifying for different parts doesn't make sense to me and I've never seen matte black kick panels or blue grey glove box doors. |
Great question. They're not very clear, are they. I think it's fairly safe to say the grille is NOT dark argent; it's regular argent. Luckily I have some Eastwood Argent in my cabinet of paint which I'll be using when I get to it.
So based on this pic of a NOS GMC grille, it is clear the GMC is dark argent on the inside slats.
And based on the NOS photos of the chrome version , I think we can say the regular grille is argent. I wish someone had a high-resolution picture of a NOS grille. Everything I found was older pics. |
![]() Join Date: Aug 2013
It's surprising there is not one dead on known color for both the GMC & Chevrolet grills. Resto boys have had years to trial & error an answer. Maybe there is, but are keeping it secret. The outside frame work of these grills (lighter) looks like Rally wheel silver.
Robert Olson Transport
![]() Join Date: Oct 2002
ive always used regular argent and its close
This is the one I used to repaint my 74 C10 grill. Came out good.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
| Bookmarks |
