06-12-2020, 09:11 AM | #1 |
Is this a 12 bolt?
This rear end has been on the FB marketplace for about a week and I'm wondering if it's a suitable swap for my 6-lug Dana 44. I've been researching options to convert my Dana to 5 lug but just haven't found a good option. I can swap axle shafts on a 12 lug pretty easy and if it's the wider rear end that eliminates the need for wheel spacers.
I want to get some measurements off it and compare to my dana to see how they compare. Does this look like a 12 bolt? The seller says it's from a 1/2 ton Chevy or GMC but doesn't know what year.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
06-12-2020, 09:27 AM | #2 |
Almost Satisfied
Re: Is this a 12 bolt?
Looks like one to me.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
06-12-2020, 11:34 AM | #3 |
Yes- thats a 12 bolt
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-12-2020, 12:49 PM | #4 |
looks like one to me.. here's the 6 lug 12 bolt under my 71 K1500 suburban you can compare with.. good luck!
I started out with nothing - and I still have most of it Last edited by Killer Bee; 06-12-2020 at 01:39 PM. |
06-12-2020, 01:04 PM | #5 |
What year had shock mounts like that....oposing direction?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
06-12-2020, 01:35 PM | #6 |
Yes its a truck 12 bolt
06-12-2020, 01:43 PM | #7 |
I edited my post, my axle pics are under a suburban, sorry I left that out..
just trying to help with the diff ID, shock mounts could be different on a p/u.. my apologies for any confusion..
I started out with nothing - and I still have most of it |
06-12-2020, 01:53 PM | #8 |
Square body trucks, Blazer, Suburbans- '73 and newer
06-12-2020, 02:46 PM | #9 |
MJN is correct it will be from a 73 to 87 K10 truck
the 67 72 K10s have the perch's on top of the diff and the 73 up have the spring perches on the bottom I initially just looked at mounts at the bottom and 6 bolt axles you will have to fab up a panhard bar mount as well for locating it as well Do you have a pic a parts kind of place start looking there My thoughts are if it dont bolt in have to change axles might as well look for a 5 bolt axle then you only have to re fab the mounts to fit another way to do this is look for a parts 67 72 truck with a 12 bolt swap diffs and sell the parts truck for what you paid for it I have done this to get a dana 44 with disc and a 205 tcase for my 69 I used to have |
06-12-2020, 03:01 PM | #10 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
06-12-2020, 03:26 PM | #11 |
I haven't look at local junkyards yet, I might do that. I thought $60 for a 12 bolt (even for 6 lug) wasn't bad. I don't know the shape of the internals though.
06-12-2020, 03:30 PM | #12 |
All about them K’s
This is correct. I don’t see how you could go wrong for $60 honestly unless it’s gots holes in the cover from it grenading. (that doesn’t appear to be the case). I know some dont care much for the truck 12 bolts but I’ve had good luck with them in the past.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
06-12-2020, 05:09 PM | #13 |
might even score a good ratio gear set or posi
06-12-2020, 05:18 PM | #14 |
The guy says he has no use for 1/2 ton axles so I'll probably grab it and see what it's got for $60. Best case, I can repaint it and rebuild the brakes and swap it out so I can actually get 5 lug rear axles and the wheels I want.
