Old 06-12-2020, 03:24 PM   #1
mygmctruck1
Radio hole fill in
I am looking for something to fill the radio hole rather than a delete plate .
I am thinking of finding a rectangular automotive clock and some how retro fitting it .
Has anyone ever done this ? In not , what kind of things have you all done ?
mygmctruck1 is offline   Reply With Quote
Old 06-12-2020, 08:27 PM   #2
Killer Bee
Killer Bee's Avatar
Re: Radio hole fill in
for installing something other than a radio, it would seem that a delete plate would be the best place to start without requiring metal work and paint.. smooth flat canvas to design your own panel mount gauges, switches, clock, etc..
I found this butchery in my blue burb.. but I opted for the aluminum adapter from brother's to clean it up for a radio..
good luck!
Old 06-12-2020, 11:06 PM   #3
OregonNed
OregonNed's Avatar
What I did (since my radio opening was hacksawed out) was to install a billet surround, and eventually put in a wood filler panel. It’s a quartersawn oak piece to compliment the glove box door and ash tray.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 06-12-2020, 11:14 PM   #4
a1vintage69
a1vintage69's Avatar
I bought the same trim plate for the BLZnCST from Brothers. pricey!
a1vintage69 is offline   Reply With Quote
Old 06-13-2020, 02:03 PM   #5
twoskies
twoskies's Avatar
few years ago, i got a piece of black plexiglass, cut it to fit and hand sanded the corners, couple pieces of 2 sided tape, mounted one of the round battery operated clocks on the outside edge, had a sticker, think mooneyes, relocated my radio beneath the dash so i wouldnt cut the dash, looked good and no permanent damage to dash
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 06-14-2020, 08:11 AM   #6
sick472
sick472's Avatar
Extra gauges can be added to the radio area. 3, small (2-1/16" diameter) gauges fit nicely if you are willing to do some cutting and drilling on the dash. It may not need opening up if the dash has aready been cut for the newer radios. I used a piece of red oak for the cover plate to match the rest of the woodwork in the cab, but any flat piece will work.
I will be putting in vacuum, oil temp, and transmission temp.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 06-17-2020, 05:20 PM   #7
mygmctruck1
All great ideas , Thank you
Old 06-17-2020, 09:53 PM   #8
Mike C
Mike C's Avatar
If it is radio sized, why not put a radio in it?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-17-2020, 09:55 PM   #9
mygmctruck1
I built a console and put a radio in it .
Old 06-17-2020, 10:12 PM   #10
yuccales
yuccales's Avatar
Or a 1/4 of a radio. I think this looks good.
yuccales is offline   Reply With Quote
Old 06-18-2020, 04:52 PM   #11
samkost
samkost's Avatar
I just filled my butchered radio dash
samkost is offline   Reply With Quote
