Old 12-12-2003, 02:44 AM   #1
9CHEVY4
timing belt gear
ok here it is i'm asking this question for my brother.
he wants to replace the timing belt with timing gear (gear drive)
is this what is it?
is that possible?
9CHEVY4 is offline   Reply With Quote
Old 12-12-2003, 03:28 AM   #2
Rooster's 67
Rooster's 67's Avatar
yes,,,, if it the right one for the application,,,,,the one pictured is also a noisy drive.....you will get a whine, sounds kinda like a blower
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-12-2003, 03:40 AM   #3
9CHEVY4
how can u tell if it's set on noisy or quiet.
thanks i did a little research on
gears
any website where i can find them
Old 12-12-2003, 05:27 AM   #4
SEVEND2
SEVEND2's Avatar
On my 350 in my 72
Pete jackson Noisey Gear drive
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 12-12-2003, 05:35 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What does your brother drive? I don't think they make many (if any) gear drives to replace belts.
Old 12-12-2003, 04:44 PM   #6
9CHEVY4
let me know if u have any info on this.
he wants to buy one but i'm not sure where to find it,
so u get the gears and still keep the timing belt?
he's got a 72 big block it's in the shop for a new paint
1969 C-10 small block
Old 12-12-2003, 04:49 PM   #7
jorgensensc
jorgensensc's Avatar
My buddy had the Not Noisy version of those gear drives and they were still noisy!! He said if he had it to do over he would just get a GOOD set of double rollers. Just an opinion though!!!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 12-12-2003, 05:24 PM   #8
Longhorn Man
OK, you're replacing a timing chain, not belt.
I guess that is my fault, when some one says belt, I picture a front wheel drive sh!t box or whatever. (Like the tiiming belt I just did last night on the wife's Contour)
The timing gears are nice and acurate, but even the quiet ones make a bunch of noise. The noise seems 'cool' at first, but if it is a daily driver, they well become very irritating in a short time.
A quality double roller will stay tight for a good 50,000, and remain serviciable for another 30,000-40,000. So in reality, the durability or extended life is not much of a selling point.
Onless it is a race only, or more time on the strip than on the street, then the only main reason to do this is for the noise.
Old 12-12-2003, 06:49 PM   #9
SEVEND2
SEVEND2's Avatar
you dump the belt/chain and install gear drive, you can get it through Summitracing. If you call them they are very knowledgeable on it
and stage 2
Old 12-12-2003, 11:56 PM   #10
Baradium
Binder Rep
Baradium's Avatar
I don't understand why they can't make them quiet.
My scout has factory timing gears and you can't hear them...
-Ryan
Baradium is offline   Reply With Quote
Old 12-13-2003, 01:58 AM   #11
Longhorn Man
Every Pontic 2.5 (151 ci Iron duke) has timing gears, as do many inlines has gears, and they are dead quiet too.
Old 12-13-2003, 02:04 AM   #12
Baradium
Binder Rep
Baradium's Avatar
I think that the reason might be the engine design.
the engines originally designed for gears probobly all have counter rotating cam and crank shaft. This allows the gears to directly intermesh instead of having to have an intermediate gear (or gears as is the case in the pictures) which maybe leads to the gear noise). The cut of the gear also affects the noise. Straight cut gears are noisier but stronger than the heli cut gears (IIRC on the second name), which are quieter.
Sound plausible?
Old 12-13-2003, 12:14 PM   #13
slam33
slam33's Avatar
most of the time those gears were also plastic. the only ones I ever found to be somewhat quiet were the Crowers that come with there own cover but do you want to spend $350.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
