Old 06-12-2020, 07:49 PM   #1
bigmac73
bigmac73's Avatar
new wheels question
guys,
I installed a set of American Racing AR91029050800 20" x 9" AR910 0mm Offset Chrome 4 Rims 5x127
on my 72C-10 , how do i know if i need longer wheel studs? and have any of your guys had to change the stud when upgrading to a 18 or 20 inch wheel??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 06-12-2020, 08:03 PM   #2
gmc684x4
Re: new wheels question
Put on a open standard lug nut on 1 stud does it have full thread contact through it
Quick easy way to see
gmc684x4 is offline   Reply With Quote
Old 06-13-2020, 07:03 AM   #3
Why would wheel diameter make any difference? It's a matter of the material thickness at the wheel lug area. Good advice on using an open lug nut to check depth of contact
Old 06-13-2020, 08:53 AM   #4
bigmac73
bigmac73's Avatar
In regards to the wheel diameter, is the mounting flange looks a little thicker than the A/R 15inch wheels i took off. I will see if i can even get a standard lug nut to fit in the hole and see what type of thread protrusion i have
Mike
Old 06-13-2020, 10:23 AM   #5
bigmac73
bigmac73's Avatar
So i went out and put on an old stock lug nut, which is 5/8 tall(or thick) and i was less than one thread from being flush ,and i did not torque it to 90ft/lbs.
So i think that the rule of thumb that i found was the diameter of the stud should be that same measurement for total thread engagement.
I have a 1/2in diameter stud and at least 1/2 in of thread engagement i think it should be fine after i fully torque them in place
Unless someone disagrees????
Mike
Old 06-13-2020, 11:47 AM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
From an engineering standpoint, there should be ~three threads protruding beyond the nut threads, since the beginning threads may not have as much thread diameter.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-14-2020, 08:29 AM   #7
bigmac73
bigmac73's Avatar
https://www.amazon.com/dp/B01A9LGP4Y...osi&th=1&psc=1
I think i might go with these for added insurance
Mike
