Ebay Junky
Removing Fenders, tough job?
i need to remove my front fenders to repaint them. how do you do it, and is it fairly complicated?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
I really don't think it's all that difficult. You start by removing the windshield wipers, then remove the cowl, then remove all the fender bolts and it should come right off. Be care if there are spacers under any of the bolts that you make a note how many where there and which bolt hole they were on. Put the fender back the EXACT same way and it should line up just fine. Hope that helps.
Alex 1971 Lil' Red 350 SBC 700R4 |
It's easier to do than explain.
Dont forget the HOOD !!!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
Um....
If you want everything to line back up once it's painted drill 1/8" holes in the hood hinge into the hood and in the fenders by the bolts into the cab. Mark where any of the body shims were removed from. I guess it would be hard if the bolt's were sized or if you were totally Wasted. Good Luck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I found some pics of the bolts. Sorry for the paint drawings. I am not a Computer Pro.
Here
