Old 12-12-2003, 02:58 AM   #1
roadking
the hei swap help?
found a hei dist for my 71 six cylinder, its out of a 78 van. my question is if i drop the new dist. in with the rotor pointing at the same direction as my old dist. rotor was pointing that it should drop right in (with maybe alittle bump of the crank) and my timing should be real close to specs. also wondering if i will have enough room, my fuel line runs between the block and dist.. any past expertise out there?
roadking is offline   Reply With Quote
Old 12-12-2003, 03:09 AM   #2
Rooster's 67
Rooster's 67's Avatar
should fit, may have to tweak or re-run the fuel line. Be sure to feed that thing a good solid 12volts, maybe even use a relay and fuse it with I belive 10amp fuse.
maybee someone can back me up on the fuse rating.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-12-2003, 03:12 AM   #3
Hooter
My other Love
Hooter's Avatar
ya don't hook the positive up to the coil cuz you only get 8 volts through it, otherwise you should be fine, but of course there will be some tweaking of the timing, to get your sweet spot
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 12-12-2003, 05:12 PM   #4
roadking
help also put new capacitor in ,dont know if i have the three wires that plug in backward. does the red wire plug into the b+ or c- side of the cap? thanks
