graphic designer
3/4 ton A-Arms on 1/2 ton Crossmember
Are the crossmembers from a 3/4 ton and 1/2 ton the same? Just the holes for the u-bolts and upper A-Arm bolts drilled a little bigger?
I am trying to put 2wd lift spindles from the '88+ series on a '70 pickup using a '73-'87 crossmember as a few have done before. I have a 1/2 ton front end but i need to use 3/4 ton lower a-arms. Hoping I can use the crossmember instead of searching out a 3/4 ton front end. |
| Bookmarks |
