Old 06-16-2020, 03:04 AM   #1
reaperz1
Radiator support problem
So I went to install the bottom bushing that hold radiator in and to my surprise they don’t fit. The new radiator support seems to be not as wide at bottom, I was wondering if anyone had an issue like this. I will take some pictures in the morning to see what you think before I start grinding on it
reaperz1 is offline   Reply With Quote
Old 06-17-2020, 03:01 PM   #2
68 P.O.S.
Re: Radiator support problem
You can't drill the holes out wide enough to make it fit?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-17-2020, 03:41 PM   #3
weq92f
weq92f's Avatar
So the bottom rubber "slot" in your support isn't big enough to accept the rubber bushing?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-17-2020, 04:15 PM   #4
Richard
Think you are talking about installing the lower radiator retainers in a new core support or one that is missing them. If you are using the HD or 4 row retainers you will need to flatten the inner edge of the core support for them to fit. Might even have to tweak a bit for the 3 row retainers. Don't grind, just flatten the lip.
Forgot about my old core support in the side yard. Added a pic, hope this helps
Richard
